23758 Discussions
Graphics Command Center Hotkey activation
christiann
Hy how can i activate the hotekey for the whole company? Is there a regkey or somthing else?
AlHill
Much mor information needed.
[Windows 11 is the new Vista]
christiann
I edit my topic with a screenshot.
what further information should i write about it?
AlHill
Enabling hotkeys is done on a per-workstation basis.  There is no key that I am aware of that will do it for a whole company.   Perhaps there is a group policy for a domain that can accomplish this.   One of the Intel support engineers will have to provide more detail.
Alberto_R_Intel
christiann, Thank you for posting in the Intel® Communities Support.
In reference to your question, Al Hill's response is correct, the best thing to do will be to get in contact with the IT department of your company to confirm if activating the hotkey for the whole company is possible and if they are able to that for you.
Albert R.
christiann
I’m from the it - We need the information how we can activate it for all.
I didn’t finde anything about that in the internet or the intel homepage
Alberto_R_Intel
christiann, Thank you very much for your response.
"Enabling hotkeys is done on a per-workstation basis.", Still, since you are from IT, we will do further research on this matter in order to confirm if there might be a method to accomplish what you are looking for. As soon as I get any updates, I will post all the details on this thread.
Albert R.
christiann
Alberto_R_Intel
Hello christiann, I just received an update on this matter.
In order to enable hotkeys by default, please try the following:
If a dword hotkey called EnableHotkeys is added in this path with the value set to 1:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000
Then when the Intel® Graphics Command Center is first invoked, hotkeys will be enabled.
Albert R.
christiann
Alberto_R_Intel
christiann, You are very welcome.
We are glad to know the information posted previously was useful and helpful for you.
Any other inquiries, do not hesitate to contact us again.
Albert R.
christiann
Hy
we tried it on some computers and it doesn't work.
is it possible that it doesn't work if the program has already been started once and the key was set after that?
