23850 Discussions
Graphics Command Center does not use the "Enable System Hotkeys" switch!
User1578570679546264
Heads up:
Even though the "Enable System Hotkeys" switch is set to off, the Graphics Command Center still binds/registers the Hotkeys listed thus making the usage of those combinations impossible in ANY OTHER APP!
Workaround: since the "off" is not working, the only option to use (default) CTRL+ALT+UP (etc.) key combinations is to specify some that will be unlikely used in other Windows apps.
Graphics Command Center (v 1.100.1725.0)
Fix this stupidity ASAP!!!!!
Lewis-H
I think there is a bug is your system which is causing this issue. Try to re-install your OS also you can raise a ticket to the support team. They can help you with exact solution.
Lewis
Ewalk7
I'm not facing this problem, maybe it's your end problem
For all the haters quick to dismiss my issue, here's the reply from Intel:
