22667 ディスカッション
Graphics Error in <Death Stranding>(DX12)
Railgun-wiki
ビギナー
7,593件の閲覧回数
  • Description:
  • An error appears like green lines between grass and sky when camera moves towords the grass. It only appear on grass and won't appear on rocks or etc. It appears in each version of Death Stranding including origin ver and director's cut and intel graphics driver including DCH and Arc & Iris Xe Graphics WHQL. It didn't appear on nvdia or amd graphics so i'm sure it was a intel driver's problem.
  • Hardware:
  • In SSU.txt or below.
  • CPU: Intel i7-1165G7
  • Memory: 16GB DDR4 3200MHz
  • Graphics: Intel Iris Xe 96eu
  • Software:
  • Driver version: Intel® Arc™ & Iris® Xe Graphics - WHQL - Windows* 31.0.101.4032
  • Game version: Director's Cut v1.001 Build 2796878.164
  • How to repro:
  • Open the game and walk for a while(it doesn't appear at once)
  • It will appear a while later when the scene changes.
0 件の賞賛
9 返答(返信)
Hugo_Intel
従業員
7,537件の閲覧回数
Hello Railgun-wiki
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing issues with Intel® Graphics on the Death Stranding game.
Please let's try the following:
1.-Do a clean installation of this same driver version 31.0.101.4032
2.-If the issue persists, for testing purposes, please do the same clean installation and test the following drivers:
Intel® Graphics – Windows* DCH Drivers
3.-Also, Could you please let us know if this issue has always happened to you? Or, Did it recently start?
Hugo O
Railgun-wiki
ビギナー
7,519件の閲覧回数
Thanks for your reply
I have fellow your advices as well as tried more drivers and the issue was still here
I'm sure the issue has happened since DCH driver 31.0.101.3222 and Arc driver 31.0.101.3959
I didn't test Arc drivers before 0.101.3959 because i thought it doesn't work well on Iris Xe graphics
The issue does have always happend to me.
Hope for your later replys
Hugo_Intel
従業員
7,498件の閲覧回数
Hello Railgun-wiki
Thank you for the information and for the testing performed.
We will continue researching this issue internally and I will post back soon with an update.
Hugo O.
Railgun-wiki
ビギナー
7,484件の閲覧回数
Thank you
I hope the issue will be soon solved
Dragossani
ビギナー
7,373件の閲覧回数
I have the same problem with the game. The graphical artefacts look identical. I have done a clean install of drivers and checked the integrity of the game files.
My hardware is a Lenovo ThinkBook 15 laptop with:
PROCESOR
11th Gen Intel® Core™ i7-1165G7 @ 2.80GHz
GRAFIKA
Intel® Iris® Xe Graphics
  • Szczegóły sterownika Aktualny
  • Dostawca Intel Corporation
  • Wersja31.0.101.4032
  • Data21.12.2022
  • Szczegóły urządzenia
  • Zgodność karty sieciowejIntel Corporation
  • Procesor wideoIntel® Iris® Xe Graphics Family
  • Rozdzielczość1920 x 1080
  • Bity na piksel32
  • Ilość kolorów4294967296
  • Częstotliwość odświeżania — bieżąca59 Hz
  • Częstotliwość odświeżania — maksymalna59 Hz
  • Częstotliwość odświeżania — minimalna59 Hz
  • Typ karty sieciowej DACInternal
  • DostępnośćDziała z pełną mocą
  • StanTo urządzenie działa prawidłowo.
  • LokalizacjaPCI bus 0, device 2, function 0
  • Identyfikator urządzeniaPCI\VEN_8086&DEV_9A49&SUBSYS_3F1917AA&REV_01\3&11583659&0&10
AUDIO
Technologia Intel® Smart Sound dla mikrofonów cyfrowych
Realtek High Definition Audio(SST)
KOMPONENTY SIECIOWE I WE/WY
TAP-Windows Adapter V9
Intel® Wi-Fi 6 AX201 160MHz
Realtek PCIe GbE Family Controller
Bluetooth Device (Personal Area Network)
Kontroler Thunderbolt 1
Intel® Wireless Bluetooth®
PAMIĘĆ
16 GB
PAMIĘĆ MASOWA
NVMe SKHynix_HFM512GD3HX015N
I would be very grateful for information when the problem can be resolved. Because the game works pretty decently but these artifacts make it unplayable sometimes...
MkBarros
ビギナー
7,361件の閲覧回数
Hi!
I am having the same issue, i already try to reload the drivers and upload to the lastest version, following the same steps that was indicated to "Railgun-wik" , but the bugs persists.
SETUP :
Processor 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz, 2803 Mhz, 4 Core(s), 8 Logical Processor(s)
Intel (R) Iris(R) Xe Graphics - 16GB RAM - Lenovo Thinkpad E14.
Any new possible resolution? This is really impacting my experience.
Best Regards.
Hugo_Intel
従業員
5,785件の閲覧回数
Hello everyone, @Railgun-wiki
This issue with Graphics corruption glitched in Deeath Stranding has been fixed in our latest driver version 31.0.101.4577. Please update to the latest version, you can use Display Driver Uninstaller to make sure previous driver installations get completely removed.
We would appreciate it if you can confirm the issue does not happen for you after updating the driver.
Hugo O.
Hugo_Intel
従業員
5,738件の閲覧回数
Hello everyone
We would like to check if you had the chance to test our latest driver, this issue should not happen in the latest version and we would appreciate it if you could confirm whether the issue is still happening on your systems.
Hugo O.
Jocelyn_Intel
従業員
5,652件の閲覧回数
Hello, everyone.
As we have not heard back from you, we will proceed to close this thread now. If you need any additional assistance, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
返信
