23838 Discussions
Graphics card updated
Louise_M
Hello
I've updated my drivers but the tv/pc HDMI connection isn't working.
Please
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Louise_M
Thanks there you go...
Louise_M
Intel says that the drivers are well updated but still having a problem connecting
David_G_Intel
Hello Louise_M
Thank you for posting on the Intel️® communities.
We see that you tested the latest drivers from the Intel website and the OS is up to date. Because of the customizations included, we recommend that you use the drivers provided by HP*. You can contact HP* to use their customized drivers, verify that the firmware is up to date and HDMI port is working properly.
David G
Intel Customer Support Technician
