23738 Discussions
Graphics driver error
DaoLoc
1.
- My computer has a 'graphics driver' error, I have tried many ways to fix it but it doesn't work. The 'graphics driver' is faulty causing my 'Powerpoint' software to show an error, everything is torn diagonally. (easiest way that I can tell), and sometimes, in 'Windows' applications also appear black diagonal lines (I haven't captured them yet) 3217b333-9839-4db0-b5e1-c35c4ea12c27.png3217b333-9839-4db0-b5e1-c35c4ea12c27.png
After I removed 'graphics driver' everything was fixed including 'Powerpoint'  162a389b-c227-4a7a-9996-81a94a4b52ff.png162a389b-c227-4a7a-9996-81a94a4b52ff.png
However, when removing the 'graphics driver', it defaults to the old 'driver', so my monitor doesn't display the correct 'resolution' (as shown in the picture). My exact monitor is: 1920x1080 ScreenShot_20211026194305.pngScreenShot_20211026194305.png
Then, I need to update it, but this also defaults to causing the 'graphics driver' to fail again
This is information about my computer: 
I need everyone's help as soon as possible so
that I can return to my work with a stable computer again. Thank you so much everyone....
AlHill
Your problem is that your processor and graphics are not supported on Windows 10 or Windows 11.
It is time for you to upgrade to a new or newer system.  I suggest you look for something with an 8th gen processor or later.
[Windows 11 is the new Vista]
DaoLoc
Thank you very much. About 5-6 months ago everything worked fine and no errors, is there any other way to fix the error other than having to upgrade my device. Currently, upgrading the device is a bit difficult for me in the current situation
AlHill
If you are a desktop, you can try adding a graphics card, like an nvidia gtx 1060 or gtx 760.
DaoLoc
Oh, thank you very muck, i will try that... Thank you
