23728 Discussions
Graphics drivers for Windows® 10 October 2018 Update (version 1809)
RonaldM_Intel
The latest Intel® HD Graphics Drivers for the following platforms should continue to work with Windows® 10 October 2018 Update (version 1809)
  • 6th Generation (codenamed Skylake) and newer platforms can use driver https://downloadcenter.intel.com/download/28180 25.20.100.6323 or newer.
    • Intel® UHD Graphics 620
    • Intel® UHD Graphics 630
    • Intel® HD Graphics 610
    • Intel® HD Graphics 630
    • Intel® Iris® Plus Graphics 640
    • Intel® Iris® Plus Graphics 650
    • Intel® HD Graphics 620
    • Intel® HD Graphics 615
    • Intel® Iris® Pro Graphics 580
    • Intel® Iris® Graphics 550
    • Intel® Iris® Graphics 540
    • Intel® HD Graphics 530
    • Intel® HD Graphics 520
    • Intel® HD Graphics 515
  • 5th Generation (codenamed Broadwell) driver https://downloadcenter.intel.com/download/28163/ 15.40.41.5058
    • Intel® Iris® Pro Graphics 6200
    • Intel® Iris® Graphics 6100
    • Intel® HD Graphics 6000
    • Intel® HD Graphics 5500
    • Intel® HD Graphics 5300
  • 4th Generation (codenamed Haswell) driver https://downloadcenter.intel.com/download/28163/ 15.40.41.5058
    • Intel® Iris® Pro Graphics 5200
    • Intel® Iris® Graphics 5100
    • Intel® HD Graphics 5000
    • Intel® HD Graphics 4600
    • Intel® HD Graphics 4400
    • Intel® HD Graphics 4200
  • 3rd Generation (codenamed Ivy Bridge) driver https://downloadcenter.intel.com/download/28164 15.33.47.5059
    • Intel® HD Graphics 4000
    • Intel® HD Graphics 2500
Embedded systems based on Apollo Lake and Gemini Lake families use driver https://downloadcenter.intel.com/download/28180 25.20.100.6323 or newer.
Embedded systems based on Braswell & Cherry Trail families use driver https://downloadcenter.intel.com/download/28163/ 15.40.41.5058
https://downloadcenter.intel.com/download/28163/ https://downloadcenter.intel.com/download/28163/Embedded systems based on Bay Trail family use driver https://downloadcenter.intel.com/download/28164 15.33.47.5059
Refer to the following article for assistance on https://www.intel.com/content/www/us/en/support/articles/000005510/graphics-drivers.html identifying your Intel® Graphics Controller.
If you see any error during the installation of the graphics driver then follow https://www.intel.com/content/www/us/en/support/articles/000005469/graphics-drivers.html this link
Note: Intel provides generic versions of software and drivers. Your computer manufacturer may have altered the features, incorporated customizations, or made other changes. We recommend using the drivers provided directly by your computer manufacturer.
dublinman1990
Hi MWood9,
I think I have a solution for your problem. I have been trying to update the graphics card for over five weeks. I hope that it will work for you.
If you have Windows 10. Here are some instructions.
Right click Start button. Click on System.
Click on Advanced system settings. When a dialog box appears on the screen.
There are two options for you to choose here.
Yes (Recommended) & No (Your device may not work as expected.)
Click on No.
Then, if you have administrator privileges on your device, click Continue.
All you have to do next is install the graphics card again on your device.
If you are installing it as a zip file. Follow these instructions.
Download the ZIP version of driver package.
Extract the zip file somewhere easy to find, e.g your "Desktop".
Go to Device Manager
In "Display Adapters" find "Intel(R) HD Graphics"
Right click on it and go to "Properties"
Now new window should appear.
Click "Driver" tab
Then click "Update Driver..." button.
A new window will appear.
Now click on "Browse my computer for driver software"
It's will show you next page.
WARNING: DO NOT click on "Browse" here! Ignore this form!
Click on "Let me pick from a list of device drivers on my computer"
In this window click on "Have Disk..." button.
A window pop's up to find the driver
Navigate to the extracted driver folder
Go to the "Graphics" sub-folder
Click on the igdlh64.inf (or igdlh32.inf if you have 32-bit OS)
It's should gone back to last window with only one driver to choose from
WARNING: Name of INF file might be different!
Select that only driver and click "Next.."
Done
If system offer to restart your PC I recommend to do that.
After you do that latest driver should be installed and working on your computer.
And hopefully it should work. Let us know if you have any problems.
AW8
Hi Ronald, hope you can help. In the latest 1809 64 bit Win10 update, device manager stops this driver from starting and causes the machine to fail back to the Microsoft basic driver. This was not an issue on 1803.
Device Manager reports this is a known error (code 48)
I know this is an old chipset, but you've been updating the driver (thanks!) . Is someone able to provide any update on whether this driver will get an update to address this issue?
dublinman1990
Hi AW8. I have the same problem as you with a code 48 for my Bay Trail graphics driver. I do see that Ronald has put up a link for the driver update. That is great & all but I don't know if I am allowed to download & install that one first because there is a customized driver on my Toshiba Satellite laptop. It is known as a Toshiba Satellite C50-B-137. I have tried on numerous occasions up to now in trying to find an driver update for it. No luck has been found so far in getting one so far from Toshiba's support website. I cannot rollback to 1803 as I already passed the 10 day rollback window for 1803. Can you offer me some advice please. Thanks in advance.
VARADHARAJAN
Valued Contributor II
Thanks for sharing the information , this will post help to other users
MWood9
Hi Ronald, similar issue as the others, I have an Asus Transformer tablet T100TA with the Baytrail chipset (Atom Z3740, x64 Family Model 55 Stepping 3) and I've loaded driver package 15.33.47.5059 for Win32, but I get the error that the "Driver failed to start" so it loads the basic Windows driver instead of the Intel driver. Error is "Code 43." The actual driver listed according to Intel Driver & Support Assistant is 10.18.10.5059.
Of course this means the graphics capability is greatly reduced. I've tried loading older drivers, but nothing seems to work. Can we expect another driver update from Intel for this older platform?
Be very sad to see a good working piece of hardware go to waste because the software interface to the hardware couldn't be worked out. Thanks!
dublinman1990
Hi MWood9,
Click on No.
Click "Driver" tab
Done
