22657 Discussions
HD 2500 graphics drivers crash in Win 7 Home Premium so can only use Standard VGA Driver
ELong2
I've just bought this PC second hand and it has a fresh Win 7 Home Premium OS on it. However I noticed it didn't run Aero. When I looked closer it was because the graphics adapter was just Standard VGA Graphics Adapter. So I tried to update it with the latest drivers, but when I reboot it crashes shortly after the initial splash screen.
I have the DQ77CP board, an i5 3470 CPU. I'm sure this has the HD2500 integrated graphics on it and that's what I've tried updating it with - even using Intel's own driver update utility.
What can I do to install the correct graphics drivers so it doesn't crash? Thanks.
Windows 7 Home Premium Service Pack 1 (build 7601)
Install Language: English (United States)
System Locale: English (United Kingdom)
Installed: 30/10/2014 10:59:53
Boot Mode: Legacy BIOS in UEFI (http://www.belarc.com/secureboot.html Secure Boot not supported) RM plc RM ONE 320 1.0
System Serial Number: WO59558305
Asset Tag: WO59558305
Chassis Serial Number: WO59558305
Enclosure Type: All-in-OneProcessor a Main Circuit Board b3.20 gigahertz Intel Core i5-3470
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
6144 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Not hyper-threaded Board: Intel Corporation DQ77CP AAG67261-300
Serial Number: BTCP31600G5N
Bus Clock: 100 megahertz
UEFI: Intel Corp. MKQ7710H.86A.0058.2013.0226.1541 02/26/2013
Jose_H_Intel1
Hi orange71, probably the manual installation method helps you.
http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics Drivers — How to Manually Install a Driver in Microsoft Windows 7*
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3711 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3711
If issue persists, please provide more information about the error message you are getting.
A minidump file may be of help in case of a Blue Screen of Death; these files are generally located in C:\Windows\MiniDump.
Other errors are described here: http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft*
ELong2
Here is the bootlog having updated the driver. So you get the black splash screen with the swirling windows in the middle then after a few more seconds before it gets to the blue boot up sequence it just stops and reboots.
Service Pack 111 6 2014 19:49:00.109
Loaded driver \SystemRoot\system32\ntkrnlpa.exe
Loaded driver \SystemRoot\system32\halmacpi.dll
Loaded driver \SystemRoot\system32\kdcom.dll
Loaded driver \SystemRoot\system32\mcupdate_GenuineIntel.dll
Loaded driver \SystemRoot\system32\PSHED.dll
Loaded driver \SystemRoot\system32\BOOTVID.dll
Loaded driver \SystemRoot\system32\CLFS.SYS
Loaded driver \SystemRoot\system32\CI.dll
Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
Loaded driver \SystemRoot\system32\drivers\ACPI.sys
Loaded driver \SystemRoot\system32\drivers\WMILIB.SYS
Loaded driver \SystemRoot\system32\drivers\msisadrv.sys
Loaded driver \SystemRoot\system32\drivers\pci.sys
Loaded driver \SystemRoot\system32\drivers\vdrvroot.sys
Loaded driver \SystemRoot\System32\drivers\partmgr.sys
Loaded driver \SystemRoot\system32\drivers\volmgr.sys
Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
Loaded driver \SystemRoot\system32\drivers\atapi.sys
Loaded driver \SystemRoot\system32\drivers\ataport.SYS
Loaded driver \SystemRoot\system32\drivers\msahci.sys
Loaded driver \SystemRoot\system32\drivers\PCIIDEX.SYS
Loaded driver \SystemRoot\system32\drivers\amdxata.sys
Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
Loaded driver \SystemRoot\system32\drivers\fileinfo.sys
Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
Loaded driver \SystemRoot\System32\Drivers\msrpc.sys
Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
Loaded driver \SystemRoot\System32\Drivers\cng.sys
Loaded driver \SystemRoot\System32\drivers\pcw.sys
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.sys
Loaded driver \SystemRoot\system32\drivers\ndis.sys
Loaded driver \SystemRoot\system32\drivers\NETIO.SYS
Loaded driver \SystemRoot\System32\Drivers\ksecpkg.sys
Loaded driver \SystemRoot\System32\drivers\tcpip.sys
Loaded driver \SystemRoot\System32\drivers\fwpkclnt.sys
Loaded driver \SystemRoot\system32\drivers\volsnap.sys
Loaded driver \SystemRoot\System32\Drivers\spldr.sys
Loaded driver \SystemRoot\System32\drivers\rdyboost.sys
Loaded driver \SystemRoot\System32\Drivers\mup.sys
Loaded driver \SystemRoot\System32\drivers\hwpolicy.sys
Loaded driver \SystemRoot\System32\DRIVERS\fvevol.sys
Loaded driver \SystemRoot\system32\drivers\disk.sys
Loaded driver \SystemRoot\system32\drivers\CLASSPNP.SYS
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Loaded driver \SystemRoot\System32\drivers\vga.sys
Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys
Loaded driver \SystemRoot\system32\drivers\rdprefmp.sys
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys
Loaded driver \SystemRoot\system32\drivers\afd.sys
Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
Loaded driver \SystemRoot\system32\DRIVERS\wfplwf.sys
Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys
Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
Loaded driver \SystemRoot\system32\DRIVERS\serial.sys
Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\System32\drivers\discache.sys
Loaded driver \SystemRoot\System32\Drivers\dfsc.sys
Loaded driver \SystemRoot\system32\DRIVERS\blbdrive.sys
Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys
Loaded driver \SystemRoot\system32\DRIVERS\vgapnp.sys
Loaded driver \SystemRoot\system32\DRIVERS\iusb3xhc.sys
Loaded driver \SystemRoot\system32\DRIVERS\HECI.sys
Loaded driver \SystemRoot\system32\DRIVERS\serenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\e1c6232.sys
Loaded driver \SystemRoot\system32\drivers\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\parport.sys
Loaded driver \SystemRoot\system32\drivers\tpm.sys
Loaded driver \SystemRoot\system32\DRIVERS\intelppm.sys
Loaded driver \SystemRoot\system32\DRIVERS\CompositeBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\AgileVpn.sys
Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
Loaded dri...
ELong2
I ran sfc to see if that brought up anything:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Jose_H_Intel1
Did you try installing the https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23061 Intel® Chipset Device Software and https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22093 Intel® Management Engine Driver?
What type of video cable are you using? Is it possible to try a different one?
ELong2
yes installed those drivers first and rebooted, all ok, then installed graphics driver and it crashes. Not sure about cable as it's an all-in-one PC so haven't opened the case. Suspect it is DVI though as when restarting you briefly get message 'DVI no signal'.
Jose_H_Intel1
Try checking in BIOS if everything is ok, you can check if there is a discrete graphics card installed by any chance or reset the BIOS settings back to default.
