22974 Discussions
HD 4000 does not activate 3rd monitor on TB connection
DH_1
Hey guys,
Now that I bought 3 new monitors due to the blackscreen issue I have a new problem
ok
GA-Z77X-UP5 TH with a i7 3770k ivy.
Can't figure this one out.... I have been reading extensively the MOBO manual and forums. I know about lots of issues and I thought I bought the right things to not have these problems.
I can only get 2 of three monitors on at one time with HD4000
I specifically built this machine with THIS MOBO to use WITHOUT a video card since intel and gigabyte were HERALDING this so loudly. I am NOT getting a ded. video card--DO NOT TELL ME TO I NEED ONE.
you can see the mobo will support 3 monitors:
http://www.gigabyte.us/products/product-page.aspx?pid=4279&dl=1# ov GIGABYTE - Motherboard - Socket 1155 - GA-Z77X-UP5 TH (rev. 1.0)
ALL MONITORS ARE THE SAME
ALL OF MY ADAPTERS WORK PERFECTLY from monoprice TB>DVI I had all 3 monitors visible at some point when switching them around so I know for a fact the adapters are not the issue.
Here is the setup.....
monitor 1: thunderbolt port # 1 out > TB/DVI adapter > DVI monitor input
monitor 2: thunderbolt port # 2 out > TB/DVI adapter > DVI monitor input
monitor 3: HDMI out > HDMI/DVI Adapter > DVI monitor input
ONCE AGAIN ****ALL OF MY ADAPTERS WORK PERFECTLY*****
windows Graphics sees all 3 and I can switch between them, but all 3 will not work at same time.
Intel graphics only shows 2 monitors....
windows graphics sees the 3rd monitor but I cannot extend the desktop to it.
I have the latest driver and latest BIOS
What is the deal?
Kevin_M_Intel
Hello lyt,
There is a configuration so that you can get triple monitor configuration in your system. The configuration is the following:
DisplayPort* + DisplayPort + HDMI* or DVI or VGA or DisplayPort or Built-in Display2
DisplayPort or HDMI or DVI or VGA + DisplayPort or HDMI or DVI or VGA + Built-in Display3
DisplayPort or HDMI or DVI or VGA or Built-in Display2 + DisplayPort or HDMI or DVI or VGA + Intel® Wireless Display (Intel® WiDi)
You can check this information at the following link:
http://www.intel.com/support/graphics/sb/CS-033714.htm http://www.intel.com/support/graphics/sb/CS-033714.htm
It is important to mention that using adapters may interfere in the signal causing problems that can affect the multiple monitor configurations.
DH_1
Thanks Kevin.
Robert U has replied to another thread that he is using passive adapters with no problems w/ screenshots.
No matter what I try, I can only get 2 of the 3 monitors to work simultaneously.
The monitors only take VGA or DVI, but I prefer not to use the VGA at all, it is 2013.
The only thing I can think of is that because there are 3 DVI monitors, and the HD4000 only puts out 2 DVI clocks, so I need a third active adapter since the signal for DVI is different than for DP. However it has been brought up that monitors that are the same... should be able to share a clock, so why does Intel HD graphics panel only show 2 monitors, while windows recognizes all 3?
