23082 Discussions
HD 4400 Gaming: Should I upgrade my driver if Im not having any issues?
KMcBr
I'm currently using Driver Version: 10.18.14.4170 on my Intel i5 4210u HD4400 Win 8.1 x64bit system, and have had very good luck running games like Elite Dangerous. I see there is a new version 15.36.28.4332 (Dec 14th), would there be any gaming performance increases or benefit in the newer version, or just bug fixes?
Amy_C_Intel
Hello, Ebojager:
At the following https://downloadmirror.intel.com/25588/eng/ReleaseNotes_GFX_15.36.28.4332.pdf https://downloadmirror.intel.com/25588/eng/ReleaseNotes_GFX_15.36.28.4332.pdf you should be able to find all the details, key issues fixed and known issues with this version.
Amy.
Amy_C_Intel
Hello, Ebojager:
Amy.
KMcBr
Thank you, I have been looking at those but never notice any performance enhancements for the 4th generation. Im guessing that has ended? Maybe I should just stick with the .4170 driver.
Are there any places here that compare graphics performance between driver versions?
Amy_C_Intel
Intel publishes all the information in regard to key issues fixed and known issues on the releases notes for each driver, if that specific driver increases performance on certain platforms the information should be on the release notes. My recommendation is to stay with the current driver, if it works for you should stick with it.
Regards.
