22679 Diskussionen
HD 530 and Opengcl
Gindelsnd2
Einsteiger
10.643Aufrufe
Hi, My PC has an Intel HD Graphics 530 card, with an updated driver.
When I try to run several programs, it tells me that an OpenGCL of at least 3.3 is required and to please update my driver. I am at a loss as to what to do. Any help would be greatly appreciated. Thank you. ,
23 Antworten
AlHill
Superuser
9.408Aufrufe
There is nothing you can do.  OpenCL 2.0 is all you have.
https://www.intel.com/content/www/us/en/support/articles/000005524/graphics.html
Gindelsnd2
Einsteiger
9.391Aufrufe
But that chart also says OpenGCL of 4.6, which is higher than what is required, yet cannot be reached. . .
Stefan3D
Geehrter Beitragender II
9.385Aufrufe
You mean OpenGL (without "C")
Download GPU Caps Viewer 1.57.1
and post a screenshot from the OpenGL tab
If it says OpenGL 1.1, then check device manager for code 43
Also try the OpenGL demos in this app.
Gindelsnd2
Einsteiger
9.366Aufrufe
Where exactly do I look in Device Manager for code 43?
Where are the demos?
Thanks very much . . .
AlHill
Superuser
9.369Aufrufe
There is no OpenGCL.   Your graphics support OpenCL 2.0 and OpenGL 4.6.
Which one are you asking about?
Gindelsnd2
Einsteiger
9.366Aufrufe
OpenGL . . . I keep putting that "C" in there, a bad habit . . .
Gindelsnd2
Einsteiger
9.366Aufrufe
Stefan3D
9.364Aufrufe
Judging from the screenshot the driver is not installed.
Right-click  start->device manager->GPU->properties
Most likely you will see there the infamous code 43
Gindelsnd2
Einsteiger
9.351Aufrufe
Stefan3D
9.347Aufrufe
So you have a laptop with NVIDIA Optimus i guess.
Install the "Intel chipset INF driver" which you find on the laptop manufacturer's support site to remove the yellow bangs under "other devices".
Gindelsnd2
Einsteiger
9.346Aufrufe
No, it is a desktop HP computer.
I have updated the drier from the Intel support site but still get the error message.
Stefan3D
9.345Aufrufe
So what is the second GPU labeled "MS basic display adapter"?
check GPU properties->details->hardware ID
Gindelsnd2
Einsteiger
9.343Aufrufe
That is a generic Microsoft Display Adapter, which is currently disabled . . .
Stefan3D
9.341Aufrufe
Interesting, that should not be there if you have only one GPU.
Create a restore point then you can uninstall the MS basic display adapter.
Reboot and check device manager and GPU Caps Viewer again.
In case of issues you can restore from the system restore point.
In any case the yellow bangs must be fixed for a properly working system.
Gindelsnd2
Einsteiger
9.337Aufrufe
No good . . .
I uninstalled the generic driver and the PC reinstalled it . . .
Everything looks exactly as it was before . . .
Stefan3D
9.335Aufrufe
I'm running out of ideas.
If it is a brand new PC, ask HP support.
If it is an old PC that worked properly at some point, revert whatever major changes you made recently.
Otherwise create a report with Intel® System Support Utility and attach it here so an Intel agent can take a look at it.
Gindelsnd2
Einsteiger
9.327Aufrufe
It has been driving me crazy.
Originally, the PC said I had an AMD Processor, and I struggled with that for a week.
I then did a factory reset, when it started ID'g it as an Intel HD 530, which seems more plausible . . .
I then updated the video driver, which is where I am at today . . .
The utility report is hopefully attached . . .
Stefan3D
9.324Aufrufe
The SSU report identifies the second GPU as Radeon HD 8830M / R7 250 / R7 M465X
"Microsoft Basic Display Adapter"
PNP Device ID:"PCI\VEN_1002&DEV_682B&SUBSYS_90F31B0A&REV_87\4&1C5A2EA&0&0008"
That matches the product specs
https://support.hp.com/us-en/document/c05281838
Gindelsnd2
Einsteiger
9.319Aufrufe
To us technical illiterates, s there anything I can do??? . . . LOL . . . Thanks . . .
Stefan3D
9.309Aufrufe
Antworten
