- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Owner of Dell XPS 15 9550 with a 4K display and Intel HD Graphics 530 and an Nvidia GeForce GTX 960M. I am running Windows 10 Pro. Since updated from windows update it crash several times each day. Roll back is not possible (grayed out). Frequent flashing of the screen and ending with blue-screen..
System Info
<?xml version="1.0"?>
1.2.0.58
04-12-2017
00:00:21.0884116
http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+530" />
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Happyswed,
Thank you for contacting Intel Communities.
Please check http://www.intel.com/content/www/us/en/support/graphics-drivers/000022448.html this article regarding TDR issue.
In this case, It is always recommended to install the OEM's (Dell) driver as they may have customized the generic Intel® Drivers to match their specifications or requirements.
You can try installing the latest graphics driver available on our website:
https://downloadcenter.intel.com/download/26669/Intel-Graphics-Driver-for-Windows-15-45-?product=88345 Intel® Graphics Driver for Windows* [15.45] Version: 15.45.16.4627 (Latest) Date: 3/23/2017
If you keep on having issues after installing the driver, I strongly recommend contacting your system manufacturer.
Please let me know how it goes.
JC
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have the same computer and I was having the same problem. Anytime my computer would wake from sleep, the screen would flicker constantly and the display driver would crash for at least two minutes, if I didn't get a blue screen VIDEO_TDR_FAILURE message first. I tried:
- Forcing an update to Windows 10 Creators Update
- Updating Nvidia drivers
- Updating Intel drivers
- Disabling either the Nvidia video card or the Intel one
None of which worked. What ultimately worked for me was downloading http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=5MVK2&fileId=3658752220&osCode=WT64A&productCode=xps-15-9550-laptop&categoryId=VI this driver from Dell's website. It's the one before this new screwy one. I was asked if I wanted to overwrite the new driver, but thankfully it allowed me to do that. I did that about 20 minutes ago and I've put my computer to sleep/woken it up several times and it's behaving as normal. I think Dell put out a buggy driver, I hope they fix this soon.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello djten23,
Thank you for sharing this information, hopefully, it will help Happyswed to solve the issue.
Happyswed, I would recommend following djten23 advice in case the suggestions before don't work.
If you keep on having issues, the best option would be to contact Dell.
JC
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Worked. Thanks a lot. Saved my day! I had three blue-screen this morning. Now its seem to be stable again.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi again.
It did NOT solve my problem. Its back. I have windows update that are waiting so i hope that will save the day. Im so behind my work now. Hope their will be a fix soon.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Going off of this: I had the same problem. The first time I was able to simply roll back the driver without manually hunting for it, but I didn't do the necessary second step of preventing Windows Update from automatically re-applying the driver update. Naturally then, upon installing the Anniversary Update, I was greeted with the same problem.
So for everyone else ending up here and discovering that the root of the issue, for most of us anyway, is the 21.20.16.4590 driver, here's the second part you should do after reverting back to 20.19.15.4531 so you don't have to keep installing the old driver after Windows updates:
1. Download Microsoft's "Show or hide updates" troubleshooter package from here: http://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab http://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab
2. Run the troubleshooter and hit "Next"
3. Click on "Hide Updates" and check off "Intel Corporation - Display - 21.20.16.4590" and hit next
4. Once the troubleshooter has hidden the update, close out of it. You can confirm that the update is hidden by running it again.
And that should prevent this problem from recurring after you've reverted back to the old driver. Hopefully Dell has gotten wind by now of how broken this driver update is. I had a 100% BSOD rate after waking from sleep/hibernate.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Cdw01 - Thank you for this. I think this may have solved the problem. Hopefully Dell updates the drivers soon!
RWK
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi rwk94,
I am glad to hear you fixed the issue with Cdw01 recommendations.
As a clarification for /message/466864# 466864 this post, when installing/updating drivers, you may go first with the processor's drivers (graphics driver) and then the discrete graphics drivers.
Please don't hesitate in contacting us back if you need further assistance.
JC
