22671 ディスカッション
HD Graphics Menu messed up (4400)
TS1
ビギナー
2,822件の閲覧回数
i have an i5 4210U and am using the lastest Intel drivers (Windows 10 64-Bit). I recently noticed that the controll panel is all messed up. I can't even change some settings. I already tried installing older drivers that previously worked. However I am pretty sure that the menu was shown correctly with this version installed some time ago. I even installed the Asus Driver that came with my notebook.
I also tried disconnecting the second Monitor since it ist full hd and the notebooks native display is not. Still no change though.
Has anyone encountered this issue before? I'd be really grateful if someone knew how to fix it.
Timo
0 件の賞賛
1 解決策
TS1
ビギナー
1,499件の閲覧回数
I probably should have searched a little more...
Sorry!
Fixed the Problem.
元の投稿で解決策を見る
2 返答(返信)
TS1
ビギナー
1,500件の閲覧回数
Sorry!
Fixed the Problem.
従業員
1,499件の閲覧回数
Hi zesdt,
No problem at all, if you need anything else let me know.
Mike C
返信
