I have to start a new thread.
i5-3570k-HD4000 Win 7 SP1 drivers 2696 and 2752, following issues noticed
- Final Fantasy XIV Benchmark: texture corruption and flickering seen in on scene. Here a screenshot: http://s1.directupload.net/images/120530/shlkrzr8.png http://s1.directupload.net/images/120530/shlkrzr8.png
- Dirt 2 (Steam version): (Bink?) videos on game start are very slow and choppy at ~12 fps, nothing major though
- Just Cause 2 Demo: stuck on loading screen on game start with every driver. Google says a lot of people suffer from this issue with other GPUs too but I never had this on my i5-2500k-HD3000
- all directx games: Anisotropic filtering not working when forced in control panel. Nothing new though because same story with HD3000. Bad for games without ingame AF option.
- various games like Gothic 2, Farming Simulator, UT2004/UMark: GPU Turbo frequency not working. HD4000 remains on the base frequency and therefore it runs much slower as it should. Some newer games had this issue with the 2696 driver. That's why 2752 is so much faster in Far Cry or Half-Life 2, it's fixed there. But some lesser-known games still suffer from it.
Enabling Vsync in control panel forces farming simulator to run in max frequency 1150 Mhz for whatever reason. It doubles the performance from 30 to 60 fps. Unfortunately this trick doesn't work in Gothic 1/2 or UMark.
edit: increasing the refresh rate from 60 to 75 HZ gives another small boost. 63-64 fps in my testing scene.
Message was edited by: Michael Schmidt
8.15.10.2696/2752/2761:
- DX11 ComputeShader Raytracing Benchmark: artefacts seen, runs fine on 9.17.10 drivers
8.15.10: http://s1.directupload.net/images/120531/zpgwc824.png http://s1.directupload.net/images/120531/zpgwc824.png
9.17.10: http://s1.directupload.net/images/120531/u3zyxved.png http://s1.directupload.net/images/120531/u3zyxved.png
Download: https://axelgneiting.de/share/csrt8x8.exe https://axelgneiting.de/share/csrt8x8.exe
- Oblivion: blue tinted screen when playing with HDR
9.17.2729/2747 on Win 7 x64:
- Mafia 2 Steam Demo: not starting, appcrash
- Hard Reset Steam Demo: freeze while loading into the game
- PLA Benchmark DX11: freeze while loading into the game (runs fine in dx9 mode)
- GPU Caps Viewer HW Geometry Instancing: Vertex shader error, GL_EXT_gpu_Shader4 is not supported
- 3dmark11: freeze while loading the Graphics Test 2
9.17.10.2753 fixed the Mafia 2 appcrash and 3dmark11 freeze for me.
9.17.10.2753 still suffers from the low clock Bug in Half-Life 2.
9.17.10.2753= 65 fps
http://s1.directupload.net/images/120604/e37ad6rd.png http://s1.directupload.net/images/120604/e37ad6rd.png
Date, GPU Core Clock [MHz]2012-06-04 14:43:08 ,350.02012-06-04 14:43:10 ,350.02012-06-04 14:43:11 ,350.02012-06-04 14:43:12 ,350.02012-06-04 14:43:13 ,700.02012-06-04 14:43:14 ,700.02012-06-04 14:43:15 ,700.02012-06-04 14:43:16 ,700.02012-06-04 14:43:17 ,700.02012-06-04 14:43:18 ,700.02012-06-04 14:43:19 ,700.02012-06-04 14:43:20 ,700.02012-06-04 14:43:21 ,700.02012-06-04 14:43:22 ,700.02012-06-04 14:43:23 ,700.02012-06-04 14:43:24 ,700.02012-06-04 14:43:25 ,700.02012-06-04 14:43:26 ,700.02012-06-04 14:43:27 ,650.02012-06-04 14:43:28 ,650.02012-06-04 14:43:29 ,650.02012-06-04 14:43:30 ,650.02012-06-04 14:43:31 ,650.02012-06-04 14:43:32 ,650.02012-06-04 14:43:33 ,650.02012-06-04 14:43:34 ,650.02012-06-04 14:43:35 ,650.02012-06-04 14:43:36 ,650.02012-06-04 14:43:37 ,650.0In comparison...
8.15.10.2761= 97 fps
http://s7.directupload.net/images/120604/2t8kchrw.png http://s7.directupload.net/images/120604/2t8kchrw.png
Date, GPU Core Clock [MHz]2012-06-04 14:57:37 ,350.02012-06-04 14:57:38 ,350.02012-06-04 14:57:39 ,350.02012-06-04 14:57:40 ,350.02012-06-04 14:57:41 ,1100.02012-06-04 14:57:42 ,1100.02012-06-04 14:57:43 ,1100.02012-06-04 14:57:44 ,1100.02012-06-04 14:57:45 ,1100.02012-06-04 14:57:46 ,1100.02012-06-04 14:57:47 ,1100.02012-06-04 14:57:48 ,1100.02012-06-04 14:57:49 ,1100.02012-06-04 14:57:50 ,1100.02012-06-04 14:57:51 ,1100.02012-06-04 14:57:52 ,1100.02012-06-04 14:57:53 ,1100.02012-06-04 14:57:54 ,1100.02012-06-04 14:57:55 ,1100.02012-06-04 14:57:56 ,1100.08.15.10.2761 boosts from idle frequency 350 to 1100 Mhz which results in 50% more fps in comparison to 9.17.10 with just 650-750 Mhz. I wonder why it clocks with 1100 Mhz instead max turbo 1150 Mhz on 2761 driver.
Google Earth strong shimmering can be seen in DirectX mode, perfectly demonstrated in this video: http://www.youtube.com/watch?v=k5T9mA6jutA&hd=1 Anisotropic filtering (AF) in Google Earth - Intel HD Graphics 3000 vs. AMD Radeon HD 6630M - 720p - YouTube
I have the same on HD4000 with newest driver 8.15.10.2778. I have tested a little bit and it seems the anisotropic filtering doesn't work at all, no difference between AF High, Medium and Off. For some reason Google Earth can't force this on Intel graphics and as we know AF forced through Intels control panel doesn't work either for directx applications (excluding some AF tester tools).
No shimmering in OpenGL mode with AF forced through Intel control panel in Google Earth. Same shimmering when set to application controlled in control panel and forced in Google Earth. That's why I think Google Earth can't force AF on Intel graphics and this is the cause for the shimmering.
8.15.10.2778:
Medal Of Honor Allied Assault Demo: appcrash on game start
OMG with every new 15.28 driver Half-Life 2 getting slower and slower. Max details 4xMSAA...
15.26.12.64.2761 64 fps: http://s1.directupload.net/images/120808/u4gswgu5.png http://s1.directupload.net/images/120808/u4gswgu5.png
15.28.2.64.2817 33 fps: http://s7.directupload.net/images/120808/ryoqgcsy.png http://s7.directupload.net/images/120808/ryoqgcsy.png
I bet the next driver will lower it once again. Crysis runs slower too.
Performance Bug in Far Cry 2 with the newest 15.28 driver detected.
15.28.0.64.2792= http://s14.directupload.net/images/120817/vyk25zlw.png http://s14.directupload.net/images/120817/vyk25zlw.png
15.28.3.64.2828= http://s1.directupload.net/images/120817/89mzonre.png http://s1.directupload.net/images/120817/89mzonre.png
From 60,5 fps down to 36 fps. What's wrong?
HD4000 causing high DPC Latency in general. Affecting my audio and video playback with any program. I.E occasionally the sound/audio will stutter or freeze for a split second. I installed DPC Latency Checker and disabled the HD4000's driver, my latency subsequently lowered dramatically to normal rates.
I'm having issues with play-back of Microsoft Windows TV (WTV) files with HD H.264 video in them. I'm getting tearing and pixelation pretty constantly. Not what I expect from a brand new top-end CPU/iGPU combo!
This is with the 8.15.10.2761 driver installed.
Geoff.
are you maybe referring to the similar issue posted on AVSForum?
If yes, it's here: /thread/30167 http://communities.intel.com/thread/30167
Cheers,
So I'm monitoring both threads (here and AVS: http://www.avsforum.com/t/1407042/official-ivy-bridge-for-htpcs-thread/150# post_22322588 *Official* Ivy Bridge for HTPCs Thread) and there doesnt seem to be any movement on this problem. Intel - is someone working on fixing the driver so eradicate these palyback issues?
G.
check this
/message/140990# 140990 http://communities.intel.com/message/140990
this problem is present since the 1st and 2nd generation and no one care about it from intel
I installed Google Earth 7 and the shimmering issue I mentioned is gone, at least for a HD4000. But should be solved for HD3000 too. Caps Viewer still crashes on HW Geometry Intancing with every 15.28 driver I tried: http://s14.directupload.net/images/121106/pne5togw.png http://s14.directupload.net/images/121106/pne5togw.png
Another one: Outerra immediately crashes. "Outerra Demo has stopped working"
Outerra requires OpenGL 3.3 support, theoretically it should work on a HD2500/HD4000.
Project CARS black screen with 2875 in dx9 mode. Runs fine with 2761. 15.28 introduced many new bugs.
Could you please confirm if tearing on Microsoft Windows TV (WTV) files playback with HD H.264 video has been resolved with driver 15.31.9.3165(9.18.10.3165) posted here?
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000&ProdId=3712&LineId=1100&FamilyId=39 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000&ProdId=3712&LineId=1100&FamilyId=39
Gothic 3: Serious graphics corruption: black & white textures, missing rendered parts, texture corruptions.
Hi All
We have posted a test driver that resolves several know issues. Please provide your feedback and results with the driver.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22181 32 bit version
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22182 64 bit version
Far Cry 2 and HL2 still very slow, HL2 now with a texture bug (very blurry) and slow. Caps Viewer Geometry Instancing not working too. It seems the bugfixes you refer are not included in 15.28 drivers, they are included in the next driver series 15.31: http://forums.laptopvideo2go.com/topic/24340-intel-gma-drivers/page__st__280# entry144816 Intel GMA Drivers - Page 15 - Intel GMA releases - LaptopVideo2Go Forums
With this driver HL2 and Far Cry 2 very fast, Caps Viewer Geometry Viewer working and faster than before, Just Cause 2 hang bug fixed, Final Fantasy texture corruption fixed. GTA4, Skyrim, and PLA Game slower but most other games faster than before from what I have tested.
This is what I meant with blurry.
15.31 2885= http://www.abload.de/img/28854lpby.png http://www.abload.de/img/28854lpby.png
15.28 2897= http://www.abload.de/img/2897abi97.png http://www.abload.de/img/2897abi97.png
The blurriness is a new bug in HL2 with the newest 15.28 driver. And over 40 fps slower than the older 15.31 driver. Same settings (16xAF).
![](/skins/images/62F5F803C638BF2554D48A7D62AEDECA/responsive_peak/images/icon_anonymous_message.png)
