Hi all, I'm trying to enable HDR using the 630 in my mac mini (2018). As this one only has HDMI and Thunderbolt/USB-C Connections, I'm using a USB-C-to-Displayport cable. The vendor of the cable explicitly mentions DP1.4 and HDR (HBR3) support, and my (main) Display is HDR600 certified. FWIW, a second (non-HDR) Display is connected, again with a USB-C-to-DP cable. Both Displays are running 4K@60Hz. I've initially suspected a bandwith limitation of the iGPU, but disconnecting the second display makes no difference. Per Apple's Documentation, this Mac should be able to support HDR. Using a different Mac (M1), and using Windows (through native DP), I was able to run the Display in HDR mode. Is this perhaps a driver or firmware issue?
I am sorry, but Apple has requested that all queries regarding their systems be redirected to them. Please contact Apple Customer Support.
Aw shucks, but thank you anyway for taking the time to respond. Let's see if their support is as good as these forums here. 🙂
Topic Options
