Avisos
22760 Discusiones
HP Elite 8100 SFF on Windows 10 64-Bit - Which graphics driver?
JWhit16
Principiante
9.177 Vistas
I need some assistance in selecting the correct driver for this system, I have been trying for 3 days to find the correct driver, without success. I have attached the intel scan in HTML format so you can see the PC specs. (if you need to)
Every driver I have downloaded so far say this "This computer does not meet the minimum requirements" when installing.
I have also download the Intel driver and support assistant, but that doesn't help my problem.
Computer is currently using Microsoft Basic Display Adapter, which won't let me go any higher than 1600x1200. It looks a mess.
Proccessor is: Intel® Core™ i5 CPU 650 @ 3.20GHz
Which driver do I need?
0 kudos
3 Respuestas
AlHill
Superusuario
7.004 Vistas
This is your 8-year old processor:
https://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-4M-Cache-3_20-GHz Intel® Core™ i5-650 Processor (4M Cache, 3.20 GHz) Product Specifications
It, and its processor graphics are NOT supported on Windows 10.
There are no drivers for Windows 10.
You will have to continue using the Microsoft generic drivers.
Doc
JWhit16
Principiante
7.004 Vistas
Really?
So i'm going to have to stick to such a low resolution?
I'll have to downgrade to Windows 7.
AlHill
Superusuario
7.005 Vistas
Really. Windows 10 is not supported on your processor and graphics.
https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html Does My Intel® Processor Support Microsoft Windows® 10?
You can certainly downgrade to Windows 7.
If you device is a desktop, and you have a PCIe x16 slot available, you may be able to add an amd or nvidia graphics card that is compatible. Compatible is the key word here.
Doc
Responder
