22661 Discusiones
HP Probook 4510s persistant graphics challenge
MNotn
Principiante
2.485 Vistas
I own a Probook 4510s Notebook - NA915EA, it's warranty is already expired.
The problem lies with the Mobile Intel(R) 4 Series Express Chipset Family [PCI\VEN_8086&DEV_2A42].
Whenever I do not install any driver for this part it works fine. The display resolution can be set to 1024x768, but I cannot connect a hdmi screen to it.
When I do install a graphics driver the following happens:
> I enable driver installation (gpedit.msc\Local Computer Policy\ Computer Config \ Administrative Settings \ System \ Device Installation \ Device Installation Restrictions \ Precent installation of devices not described by other policy settings -> Not Configured)
> I install the driver, WinSAT & Aero enabled.
> I disable driver installation to prevent windows from messing up
> I restart the Probook
> The Probook loads all drivers fine
> The welcome screen appears with black pixels all over the screen
> The welcome screen refreshes 3 times; every time the pixels are on a different place
> Blue Screen of Death
Technical information:
STOP: 0x0116 (0xFFFFFA80072C0010, 0xFFFFF88002A4CB0, 0x0..0, 0x0..000D)
igdkmd64.sys - Address FFFFF88002A4CB0 base at 0xFFFFFA80072C0010, DateStamp 4a01d55b
> I enable driver installation (gpedit.msc\Local Computer Policy\ Computer Config \ Administrative Settings \ System \ Device Installation \ Device Installation Restrictions \ Precent installation of devices not described by other policy settings -> Not Configured) (same as above)
> I install the driver, WinSAT & Aero disabled.
> I disable driver installation to prevent windows from messing up (same as above)
> I restart the Probook (same as above)
> The Probook loads all drivers fine (same as above)
> The welcome screen appears with black pixels all over the screen (same as above)
> The welcome screen refreshes 3 times; every time the pixels are on a different place (same as above)
> Screen turns black and desktop appears
> Spam pop-up:
- Display driver stopped responding and has recovered,
- Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has sucessfully recovered.
> The Probook freezes and I am forced to shut it down
I run Windows 7 - 64 bit with Service Pack 1
I hope there's someone out there with the solution
0 kudos
1 Responder
DArce
Colaborador Valioso III
1.607 Vistas
The error message you get in the second scenario is similar to what has been described and troubleshoot on this thread:
/thread/32928?start=375&tstart=0 http://communities.intel.com/thread/32928?start=375&tstart=0
Try using the latest driver that has been provided by Hewlett Packard* for your system and install the latest BIOS for your computer. This is available here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3934828&taskId=135 HP ProBook 4510s Notebook PC | Download drivers and software - specify product name - HP Business Support Center
Responder
