Hi Intel community, I'm having big issues playing halo on my laptop.
I always get these wierd effects:
http://i.imgur.com/s30u9d7.jpg http://i.imgur.com/s30u9d7.jpg https://imgur.com/a/q6CkA
http://i.imgur.com/ilG5Ct2.jpg http://i.imgur.com/ilG5Ct2.jpg
I tried uninstall and reinstall Halo, I did the same with the graphic driver but I got the same result. I actually update the latest Intel Graphic Driver with the Utility provided by Intel itself, which is x.x.x.4501 (correct me if I am wrong).
anyway, those are my specs:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.160902-0600)
Language: Italian (Regional Setting: Italian)
System Manufacturer: HP
System Model: HP ProBook 440 G3
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 8192MB RAM
Available OS Memory: 8088MB RAM
Page File: 4330MB used, 11844MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Display Devices
Card name: Intel(R) HD Graphics 520
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_1916&SUBSYS_8100103C&REV_07
Display Memory: 1824 MB
Dedicated Memory: 192 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO1B3D
Native Mode: 1920 x 1080(p) (60.056Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 20.19.0015.4444 (English)
Driver Version: 20.19.15.4444
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/27/2016 16:13:12, 39856528 bytes
WHQL Logo'd: Yes
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Hello espoice,
According to your report, the current driver installed is .4444, can you double check if this is the right version? Go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed. If you see the same number, use this method http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7* in order to install version .4501.
Amy.
hello Amy, thanks for replying.
I actually checked the driver version on Device Manager and it is said to be the .4444. Anyway, when I attempt to install the driver version .4501 either with the Intel Driver Utility or manually, I get the following error: "The driver being installed is not validate for this computer. Please obtain the appropriate driver from the computer manufacturer. Setup will exit.
Waiting for your answer,
Stefano
This method http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7* will help you to overcome the error message you got.
Please give it a try and let me know how it goes.
Amy.
Hello Amy, I follow your instruction downloading the right graphic driver .4501 for my System and Graphic card. When I open Device Manager and go to Display Adapter, I select update driver browsing my computer and selecting the folder where I downloaded the .exe stated above. A window immediately pops up and says: "Windows has determined the driver software for your device is up to date" and nothing more.
Should I completely unistall the graphic driver and try again ?
Stefano
Yes please, try uninstalling the current driver version installed. I recommend using this method;
- Open the Device Manager
- Expand the Display Adapters section.
- Find the Intel Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
- Right click Intel Graphics Driver and select Uninstall.
- Select the check box Delete the driver software for this device.
- Reboot the computer after uninstall process has finished.
- Try one more time installing the driver .4501,
Once done, double check if the driver was successfully install by checking the version.
Let me know how it goes.
Hello Amy!
After uninstalling the graphic driver and then rebooting in Safe Mode, the setup run flawlessly! I checked on device manager and it finally says Driver .4051 installed! Thanks for the support.
Stefano
Awesome , enjoy your game!
If you need further assistance let us know.
Amy.
/thread/107199 espoice,
I am following up your case; were you able to double check the driver version? Version .4501 might help to address the glitch issue with your game. So just make sure that you have it installed, and let me know.
Amy.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
