22925 Discussions
Hardware Raytracing broken in Blender 4.4.3 after installing libze-intel-gpu-raytracing
Jaakan-Shorter
I upgrade Ubuntu 24.10 to 25.04 , intel-level-zero-gpu-raytracing was still installed and cycles + GPU in Blender 4.4.3 ran just fine.
Operating system: Ubuntu 25.04 + Intel's repo
Graphics card: Intel(R) Arc(TM) A750 Graphics
I cleaned up the old drivers and installed the ones for the version of Ubuntu I am running
https://dgpu-docs.intel.com/driver/client/overview.html
in Blender under system > OneAPI list A750 and is checked and has Embree checked
I hit render
oneAPI queue initialization error: got runtime exception "Hardware Raytracing is not available; please install "intel-level-zero-gpu-raytracing" to enable it or disable Embree on GPU."
I opened this issue with the blender devs too
https://projects.blender.org/blender/blender/issues/140631
error in debuging logs in blender
Failed to load Ray Tracing Support Library libze_intel_gpu_raytracing.so
ldd /usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so
linux-vdso.so.1 (0x000073c20e6ac000)
libtbb.so.12 => /lib/x86_64-linux-gnu/libtbb.so.12 (0x000073c20e608000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x000073c20e200000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x000073c20e511000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x000073c20e4e4000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x000073c20de00000)
/lib64/ld-linux-x86-64.so.2 (0x000073c20e6ae000)
ll /usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so
-rw-r--r-- 1 root root 182528 May 2 12:12 /usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so
locate libze_intel_gpu_raytracing.so
apt list --installed | grep intel
intel-gsc/plucky,now 0.9.5-0ubuntu1~25.04~ppa1 amd64 [installed]
intel-media-va-driver-non-free/plucky,now 25.2.4-0ubuntu1~25.04~ppa1 amd64 [installed]
intel-metrics-discovery/plucky,now 1.14.180-0ubuntu1~25.04~ppa1 amd64 [installed]
intel-metrics-library/plucky,now 1.0.196-0ubuntu1~25.04~ppa1 amd64 [installed]
intel-microcode/plucky-updates,plucky-security,now 3.20250512.0ubuntu0.25.04.1 amd64 [installed,automatic]
intel-ocloc/plucky,now 25.18.33578.11-1~25.04~ppa1 amd64 [installed]
intel-opencl-icd/plucky,now 25.18.33578.11-1~25.04~ppa1 amd64 [installed]
libdrm-intel1/plucky,now 2.4.124-2 amd64 [installed,automatic]
libze-intel-gpu-raytracing/plucky,now 1.1.0-0ubuntu1~25.04~ppa1 amd64 [installed]
libze-intel-gpu1/plucky,now 25.18.33578.11-1~25.04~ppa1 amd64 [installed]
xserver-xorg-video-intel/plucky,now 2:2.99.917+git20210115-1build1 amd64 [installed,automatic]
Jaakan-Shorter
A few quotes from the Blender Devs, that might help get this issue fixed.
--- In previous versions, the library was using onetbb statically, and here we see it's not the case anymore. This is the breaking change as now it fails to load from Blender.
Which version of onetbb do you have? I see in kobuk ppa logs, the library has been built with 2022.0.0-2. In theory, as a workaround, pre-loading this version or a newer libtbb.so.12 should work for both the lib and blender.
--- based on the provided information, the problem is clear: there is some issue with a shared library from the Intel package here, because you can clearly see that there are some symbol failures:
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so blender /snap/blender/6181/blender: symbol lookup error: /usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so: undefined symbol: _ZN3tbb6detail2r127get_thread_reference_vertexEPNS0_2d126wait_tree_vertex_interfaceE
let me know if there is anything else I can do to help
RandyT_Intel
Hi @Jaakan-Shorter,
Thank you for sharing these details. I will coordinate internally to investigate the issue and findings from the software development team . We will assess whether it can be resolved on our end. I will provide you with updates and instructions as soon as I have more information. In addition, Please provide the SSU log report and share it here so I can review your system's configuration. Your patience is appreciated.
Randy T.
Jaakan-Shorter
I have attached the SSU log
RandyT_Intel
Hi @Jaakan-Shorter,
We are currently working on recreating the issue you reported, and I would like to clarify the steps you followed to ensure accuracy:
  1. You cleaned up the old drivers and installed the ones for the version of Ubuntu you are running, as per the instructions here:  https://dgpu-docs.intel.com/driver/client/overview.html
  2. In Blender, under System > OneAPI, the A750 is listed and checked, along with Embree.
  3. You hit render.
Could you please confirm if these steps are correct? Additionally, if possible, could you provide a sample file that demonstrates the issue? This will help us recreate the problem more efficiently.
Randy T.
Jaakan-Shorter
Sorry, I totally forgot the steps for Cycles, I attached a test project with Cycles+GPU compute already selected
  1. Cleaned up the old drivers and installed the ones for the version of Ubuntu currently running ( 25.04 ), as per the instructions
  2. Open Blender, either leave the default cube or open a project
  3. Go to Edit > Preferences > System > OneAPI, Make sure A750 is listed and checked, along with Embree.
  4. Go to Properties > Render/Render  Properties > Make sure Render Engine = Cycles and Device = GPU compute
  5. Go to Render > Render Image
Screenshot From 2025-06-24 19-12-59.pngScreenshot From 2025-06-24 19-12-40.png
Screenshot From 2025-06-24 19-31-43.pngScreenshot From 2025-06-24 19-32-27.png
RandyT_Intel
Hi @Jaakan-Shorter,
Thank you for providing the requested information. I will begin replicating the issue on our end and will update you once my analysis is complete. If I require any additional details, I’ll reach out to you here.
Randy T.
Jaakan-Shorter
One of the Blender Devs posted a working around, which might point you in the right direction of the issue.
instead of
blender
do the following with the current packages
LD_PRELOAD="/usr/lib/x86_64-linux-gnu/libtbb.so.12 /usr/lib/x86_64-linux-gnu/libze_intel_gpu_raytracing.so" blender
JaveA_Intel
Hi @Jaakan-Shorter,
Thank you for providing this information. We are still investigating on this issue. We will get back to you as soon as possible.
Jave Vincent A.
Ernesto_C_Intel1
Hi @Jaakan-Shorter
Thank you for your patience. I'm contacting you on behalf of my technician, Randy. Allow me more time to recreate the issue you've raised.
I'll provide an update as soon as possible.
Ernesto C.
VonM_Intel
Hi @Jaakan-Shorter
Thank you for your continued patience. We've successfully recreated the issue on our end using Ubuntu 25.04. At this point, we're proceeding with a deeper investigation to identify the root cause and determine a proper solution. Please note this may take some time, but we’re on it.
We’ll keep you informed with any relevant updates as soon as they’re available.
Von M.
malcolmlewis
Hi @VonM_Intel
I'm the packager/maintainer of the intel-level-zero-gpu-raytracing package currently in a development repository for openSUSE. This is still an issue with both the tarball version of blender-5.0.0-linux-x64 and benchmark-launcher-cli-3.1.0-linux, in both case for it to work users need to add; `LD_PRELOAD="/usr/lib64/libze_intel_gpu_raytracing.so /usr/lib64/libtbb.so.12.16"`
I would like to submit this library to openSUSE Tumbleweed, but can't until this issue is resolved, so was wondering if any further progress has been made?
