Both monitors worked with HDMI, here are some specs to assist you: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHZ 16 GB of RAM 64-bit operating system x64-based processor
- Tags:
- Graphics Driver
Update the ASUS bios. Contact Asus for help with that (haha).
Doc
Thank you for help but, i updated the bios and the monitor still didnt connect to the display port. Any advice haha?
Are you using the driver provided by ASUS?
Have you tried different/quality cables?
Doc
I have tried 2 different cables and they both didnt work, the driver is provided by microsoft (if i found where my drivers information are correctly)
Also, what is your processor model number?
What version of windows 10? 1909?
Doc
it is windows 10, sorry to ask but where can i find the processor model number?
You can find both the windows version and processor model number in START, SETTINGS, SYSTEM, ABOUT:
Doc
it is windows 10 version 1903 and i still cannot find the processor model. Could you give me an example of what it would look like?
When you go to START, SETTINGS, SYSTEM, ABOUT, above where you found the version, look for Device Specifications, Processor.
Doc
it doesn't specify and just shows "Intel(R) Core(TM) i7-6700 CPU @ 3.40GHZ"
you have an i7-6700 processor.
This is the latest driver for your intel graphics:
https://downloadcenter.intel.com/download/29426?product=88196
You should be able to download and install the exe version. This is assuming you do not have an add-on graphics card (like nvidia or amd). Do you know if you have nvidia or amd? If you do not have those, then install the Intel driver.
Doc
I don't believe i have nvidia or amd, is there anyway to check?
you can look in the device manager, or run dxdiag, or look at the back of your PC.
Or, you can download, run, and attach (using the paperclip) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
Can you take a photo of the back of your PC and attach it?
Doc
just of the plugs? my pc is prebuilt and i can send you a link of the ASUS site where it came from.
Just a photo of the back, or the SSU report.
Or, the complete model number (as there are several versions of your PC)
Doc
can you still add a photo of the back of the PC?
Doc
