22963 Discussions
Homefront couple of bugs and DXGI_ERROR_DRIVER_INTERNAL_ERROR
Parapele
Hello everyone! This bug report will be very different. Driver 15.33.35.4176 /message/290277 https://communities.intel.com/message/290277 has support for this game, but right now it's a mess.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Corrupted graphics, crash. Just read below.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
custom GIGABYTE H110M-S2H i3-6100
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
only HD 530
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
SAMSUNG SyncMaster 204B
How much memory [RAM] in the system (see note2 below).
8Gb DDR4 2133
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
Hardware Stepping (see note1 below).
Stefan3D
Parapele schrieb:
First of all, i'm not can you show how looks bugs. If you don't playing in game as normal and load save straight to the level, bugs disappears.
So don't use save from internet to get level with bugs faster. For demonstration where bugs appears i will use let's play from youtube.
Let's start from crash. This is 5 hour game, it crashed for me twice. This is what popup on screen when game crashes.
http://imgur.com/a/VDnIy http://imgur.com/a/VDnIy
I finished game and was thinking that i can return and record bugs, but when i loading checkpoint its all ok.
There nothing i can do, and i not can check when bugs will be fixed, sorry. So this is i will left for future players.
Since the error message pin-points a specific location in the source code of the game, it should be fixable by the game developer.
https://msdn.microsoft.com/de-de/library/windows/desktop/bb323259(v=vs.85).aspx "Vertex buffer" looks like a broad hint.
I love the directory name reading "STABLE"
Parapele
Well, damn. Let's wait what Intel say...
RonaldM_Intel
Hello Parapele,
Can you try running the game in compatibility mode (either Win7 or Win 8.1) and see if you run into the same issues?
In addition, is this Homefront Steam's version? http://store.steampowered.com/app/55100/Homefront/ Homefront on Steam
Thanks for your feedback, and Stefan3D we really appreciate all your inputs!
Kindest Regards,
Ronald M.
Parapele
Only one version exist. Actually i was thinking i'm just gonna wasted 20 min... and god dammit, Windows 7 compatibility and administrator mode fixed problem, at least with bush. Thanks for your time. Bug report can be closed.
