23803 Discussions
How do i add more ram
SShan10
So I want to play city Skylands but according to will it run. I need more dedicated video card ram how do I add more. my specs are
and i need 512 or something like that
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi--eWn-NXQAhXr24MKHTeGB7MQFggwMAU&url=http://www.systemrequirementslab.com/cyri/requirements/cities-skylines/12489&usg=AFQjCNE-XdEHGHZ_iyD8s61oMiK80iicWQ&sig2=plhDneMGIWtp13JhH65qiA Cities: Skylines system requirements | Can I Run Cities: Skylines
Stefan3D
Check out:
Hello Jacksharkben ,
In most cases, your computer manufacturer has already configured your computer to use the maximum amount of graphics memory possible. This maximum amount supported by your computer can be less than the maximum amount supported by Intel® graphics. Check with your computer manufacturer for the actual maximum graphics memory supported by your computer and if it is possible to increase the amount of graphics memory.
The amount of graphics memory in use is dynamically allocated to balance the needs of the operating system and all running applications.
The link provided above by Stefan3D is good as well.
Ivan.
