23834 Discussions
How do i update my Intel(R) HD Graphics 520 That is Version 27.20.100.9664 To Version 30.0.101.1340
Nextloyed
How do i update my Intel(R) HD Graphics 520 That is Version 27.20.100.9664 To Version 30.0.101.1340 Or Newer
  • Adapter CompatibilityIntel Corporation
  • Video ProcessorIntel® HD Graphics Family
AlHill
The latest/last driver for your 6th gen processor is here:
https://www.intel.com/content/www/us/en/download/762755/intel-6th-gen-processor-graphics-windows.html
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
Nextloyed
any guide do i just install the .exe and run it as admin it will automatically update the version of driver?
AlHill
Dowmload the driver, double click on it, and follow the bouncing ball.
Have you ever installed a driver before?
Nextloyed
 I have never Installed a driver before
i install the .exe run it as admin and then let it install right??
AlHill
Where is this "run it as admin" coming from?
Now I think you should visit a PC repair shop for assistance.
Nextloyed
my bad it shouldnt be run as admin sorry
Nextloyed
i downloaded the .exe and run it am i doing right?
Nextloyed
When it comes to install graphics driver it shows this im rebooting and trying again
AlHill
So the Intel customer support technicians can have more information about your system, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Nextloyed
Bro i rebooted and i started the installation again the graphics driver installed and  the audio also and installation complete is and my Intel Graphics Driver version is 31.0.101.2115
AlHill
Glad it worked.
Be advised that Windows Update may choose to install an older version.
If so, report back and I will tell you how to correct that.
Nextloyed
Bro but now i connected my printer to my laptop its not working i opend device manager see how can i update printer driver version also
AlHill
This is not an Intel problem.
I would remove and re-add the printer.
Nextloyed
AlHill
What OS are you runnint? W10 or W11?
If W11, then:
  • Settings
  • BT and Devices
  • Printers and scanners
  • select your printer
  • Remove
With all that, you should be able to find Add Printer to install it.
Nextloyed
AlHill
Then, the w11 steps should be close.
Going offline now - you are on your own.
aG_303_
Why did you even bother to ask which OS if the W11 steps are close enough? You could be a lot more useful if you gave actual instructions with the information. They asked HOW to update, not where can they find whatever driver. If they knew what to with that driver link they wouldn't be here asking for help. As a Super User maybe you take for granted the things you know that a Beginner has no idea about? Do better.
AlHill
@aG_303_ You are just another user jealous of status rankings.  Move along, there is nothing to see here.
