Up to 3 monitors, 1 monitor per display port.
Multiple Display Configurations
The following multiple display configuration modes are supported (with appropriate driver software):
• Single Display is a mode with one display port activated to display the output to one display device.
• Intel Display Clone is a mode with up to three display ports activated to drive the display content of same color depth setting but potentially different refresh rate and resolution settings to all the active display devices connected.
• Extended Desktop is a mode with up to three display ports activated to drive the content with potentially different color depth, refresh rate, and resolution settings on each of the active display devices connected.
The digital ports on the processor can be configured to support DisplayPort*/HDMI/DVI. For Desktop designs, digital port D can be configured as eDPx4 in addition to dedicated x2 port for Intel FDI for VGA.
Source: https://www.intel.com/content/www/us/en/processors/core/desktop-5th-gen-core-family-datasheet-vol-1.html Desktop 5th Gen Intel® Core™ Processor Family Datasheet, Vol. 1 page 35 ff
連結已複製
Hello Relder,
Thank you for contacting the Intel community.
Yes, that is good information Stefan3D provided above, you can also check the following link for frequently asked questions about 3 displays configuration.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005556.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005556.html
Please bear in mind that it is recommend getting better performance to use straight connection but if you need to use an adapter I suggest you to use and active adapter instead of a passive adapter.
Ivan U.
