20671 Discussions
How to Fix “The Driver Being Installed Is Not Validated For This Computer” ?
MDana2
Annotation 2019-01-07 203934.jpghi . i have Asus N551vw laptop with Intel® HD Graphics 530 . i want to update intel driver to lastest version "DCH 25.20.100.6471" but when i want to install that, this error happens ximg_5a872e3ccbfdd.png.pagespeed.gp+jp+jw+pj+ws+js+rj+rp+rw+ri+cp+md.ic.ybVinjY4Vb.png
Windows 10 pro build 1809
N551vw Asus support page : https://www.asus.com/Laptops/N551VW/HelpDesk_Download/
what should i do ?!
Leonardo_C_Intel
Hello MDana2 Thank you for posting in the Intel Community. • Have you tried uninstalling the current graphics driver version on the system and installing the the new graphics driver? For that follow these steps: o First, you will have download the Intel® HD graphics 530 driver version on the following link https://downloadcenter.intel.com/downloads/eula/28435/Intel-Graphics-Windows-10-DCH-Drivers?httpDown=https%3A%2F%2Fdownloadmirror.intel.com%2F28435%2Fa08%2Fdch_win64_25.20.100.6471.exe , once the driver is downloaded please make sure that the unit is not connected to internet during the uninstall/install driver to avoid any automatic update, and follow these steps to uninstall the graphics drivers: 1. On the keyboard, press WinLogo key + R, then type in devmgmt.msc 2. Expand the Display Adapters section. 3. Find the Intel® Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver). 4. Right-click the Intel Graphics Driver and select Uninstall. 5. Select the check box “Delete” the driver software for this device. 6. Reboot the computer after the uninstall process has finished. o Once this has been completed install the driver downloaded previously. • Have you confirmed if the operating system has all the updates installed on the system? 1. Go to Windows® settings. 2. Update and security. 3. And scan for updates. • Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility • Steps to save the report: 1- Run the utility. 2- Click on “Scan” to get the scanned system. 3- Once the scan is complete click on “next”. 4- Use the “save” option, save the report to your desktop. 5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello MDana2 I was checking your case and would like to know if have performed the steps above. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
RAJU2529
New Contributor III
first download the driver 25.20.100.6471 from direct link
https://downloadmirror.intel.com/28435/a08/dch_win64_25.20.100.6471.exe
and then extract the file .exe C:\intel\driver to using 7-zip software , after that go to device manager , find inter hd graphics 530
right click on intel hd graphics
then choose update , choose browse my computer for driver software
browse the folder to say C:\intel\driver
put tick mark , click next , wait for 3 minutes
it completes with own analysis
restart the windows
Thats it
