23089 Discussions
How to change the refresh rate to 75Hz from 60Hz?
CSmit17
This is my current monitor: https://www.amazon.co.uk/gp/product/B015510R4M/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 AOC G2460VQ6 24 inch LED Gaming Monitor (75 Hz, Display Port, HDMI, VGA, Anti-Blue Light, Adaptive Sync/Freesync Compatible)
Which as you can see runs at 75Hz, however my graphics card refresh rate is 60Hz, from what I understand if you have 75Hz over 60Hz you get a smoother image, however couldn't manage to change this to 75?
Hopefully as seen by the attachment I get a very limited choice between 59-60 Hz, and was wondering if I could change this to 75? Cheers.
PC Specs:
i3 6100
HD 530 Intel's Integrated GPU
2x4gb 2133 RAM
250GB SSD
(Just put in the important ones)
Hello Callum:
The resolutions supported by the Intel® i3-6100 are the following:
Max Resolution (HDMI 1.4): 4096x2304@24Hz
Max Resolution (DP): 4096x2304@60Hz
Max Resolution (eDP - Integrated Flat Panel): 4096x2304@60Hz
The maximum resolution is at 60Hz, 75Hz is not supported by the processor.
You can confirm that information on the following link:
http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i3-6100%20Processor%20(3M%20Cache,%203.70%20GHz) http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i3-6100%20Processor%20(3M%20Cache,%203.70%20GHz)
Alberto
