23793 Discussions
How to collage display programmatically?
Whitesoft
I know that I can collage display by Intel® Graphics Control Panel and Intel® Graphics Command Center.
However, can I collage display programmatically? Whatever the solution is Windows API, Intel API, Powershell, Command Line or any other document.
I have searched Google and StackOverflow, but no solution found. I even tried to edit registry directly, but it didn't work.
Waiting for help, thanks!
Maria_R_Intel
Hello Whitesoft,
Thank you for posting on the Intel* Community.
To better assist you, please provide us the below information:
  • How are you connecting the displays? Please include the video ports and if you are using a straight-through connection or adapters
Please run the following tool in Windows* and attach the report generated. 
Intel® System Support Utility (Intel® SSU) 
  • Intel® SSU Download
  • Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". 
  • Click on the menu where it says "Summary" to change to "Detailed View". 
  • To save your scan, click on "Next", then "Save". 
With all the external displays connected, provide the Intel* Graphics Command Center report:
>Go to the Intel Graphics Command Center
>Support
>System Diagnostic
>Generate report.
>Attach the report file.
Maria R.
Whitesoft
Thank you for your reply.
I have followed your guide and create the reports you need. Please check the attachments.
More information I can give you:
1. I will always collage displays horizontally
2. I will always use HDMI to collage displays
3. All displays have the same size, whether it is physical or display resolution
4. I am not sure the physical size and display resoluction of the display, because our company have more than one model of machine. I must be compatible when programming.
Maria_R_Intel
Hello Whitesoft,
Thank you for your response.
I checked this internally and unfortunately, the only way to set Collage/Combined mode is through Intel* Graphics Command Center.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
