23088 Discussions
How to enable 10bit color depth of UHD Graphics 630 and ASUS PA249Q
User1590060202627670
OS: Windows 10 64 bit
Monitor: ASUS PA249Q
Intel UHD Graphics 630
(Driver Version: 27.20.100.8190)
DisplayPort 1.2
In Windows 10
Color Depth always 8bit
But MacOS can set to 10bit
​How can I set color depth to 10bit in Windows 10?
AdrianM_Intel
Hello User15900602026276700805,
You mentioned that you were able to set up 10bit color depth on macOS.
What is your system model? do you have an Apple* system?
What is the system model of the system that has Windows* 10?
Adrian M.
My Computer is MAC Mini 2018
i5 8500B with UHD graphics 630
Use bootcamp to run Windows 10 1909 64bit​
Thank you.
AdrianM_Intel
Thank you for your response.
We recommend you to contact apple* support for further assistance with Apple* devices.
In the meantime, I would like to inform you that we are currently working on Intel(R) Graphics Command Center to show a color depth option then this set would be possible in the coming releases, Therefore we recommend keeping an eye on the new releases to check it out.
it's important to know that the monitor/TV needs to be capable to handle 10 bits as well use the appropriate cables and straight connections then the controller, driver, and OS will determine what configuration to use for color depth, there could customizations performed by the system manufacturer that might cause not to get this.
Adrian M.
ADolo1
Hello. Can I join you?
I have same question: how to enable 10-12bit colour? With intel HD630 colour is always 8 bit. Even if I enable HDR in windows settings, colour became 8bit with dithering, but not 10bit. How to watch UltraHD discs which 10bit coded?
On the screenshots same monitor connected to different videocards.Untitled2.png
AdrianM_Intel
Hello ADolo1,
To answer your question we are currently working on Intel(R) Graphics Command Center to show a color depth option then this set would be possible in the coming releases, Therefore we recommend keeping an eye on the new releases to check it out.
it's important to know that the monitor/TV needs to be capable to handle 10 bits as well use the appropriate cables and straight connections then the controller, driver, and OS will determine what configuration to use for color depth.
If you have more questions, please open a new thread since every system configuration is different.
Adrian M.
adventurer
Now is Oct 2020.
I'm also keenly waiting for a Intel Graphics Command Center that has color depth option.
Still no development ?
stna1981
Hi @AdrianM_Intel,
can you give an update on the ETA of the manual color depth setting?
Best regards
Stefan
ADolo1
I have to apologies for my statement about HDR mode and 8bit colour. It was my AV-receiver's settings. I made some adjustment to it and now in HDR mode I get 10bit colour.
