23851 Discussions
How to enable integrated GPU without connecting display
JimAtActiv
Hello-
I have a PC configuration that has a NVidia graphics card on the PCIe with my system display connected to the NVidia GPU.  I enabled the Intel integrated GPU via BIOS settings.  Unfortunately, it seems that the Intel GPU is not active unless I have a display connected to the PC's HDMI port.  I would prefer not to have a display connected to the PC's display port if possible, and keep the Intel GPU active.  Is there any way to do this?
CPU: i7 2.6GHz
OS: Windows 10 Enterprise LTSC
Thanks!
Jim
AlHill
Which i7?
What version of W10 LTSC?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
JimAtActiv
Thanks for the quick response!
CPU: i7-8850H running @ 2.6GHz
OS: Windows 10 Enterprise LTSC, version 1809
Hope this helps.
Jim
AlHill
LTSC 1809 was 4 years ago.
You can use a dummy like this:
https://www.amazon.com/gp/product/B07C4TWZRM/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1&pldnSite=1
JimAtActiv
Two questions:
1. Do you know if a more recent version of windows can support the Intel integrated GPU without a display connected to it?
2. Do you know of a way with LTSC 1809 for me to have a fixed (file based) EDID which could 'spoof' the OS to thinking there is an attached display?
Thanks again...
Jim
AlHill
No, and no.  Besides, those are Microsoft questions.
Also, Intel only supports the current and three versions back of Windows 10.
JimAtActiv
Thanks for the help.
Jim
