23083 Discussions
How to setup anti aliasing / FSAA on Intel Graphics / NUC on Ubuntu ?
mobuche
Anti aliasing is running perfectly on an application running under Windows 10 on Intel Graphics UHD  series embedded in a NUC.
But the same application running under Ubuntu 22.04 and the same hardware, the anti aliasing doesn’t seem to be available, typically glGetIntegerv GL_SAMPLE_BUFFERS_ARB and/or GL_SAMPLE_BUFFERS return 0 samples.
The main difference is that on Windows, there is a driver configuration application (https://www.intel.fr/content/www/fr/fr/support/articles/000055840/graphics.html) that allow to setup anti aliasing (enable/disable/let app choose), but on Linux it seems that this tool doesn’t exist.
I’ve also tried via the  xorg.conf files (https://wiki.archlinux.org/title/intel_graphics, https://man.archlinux.org/man/intel.4#CONFIGURATION_DETAILS), butI  didn’t find anything regarding anti aliasing.
Thanks a lot for any clues !
The chipset and drivers characteristics  are:
https://www.intel.com/content/www/us/en/support/articles/000005520/graphics.html
lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphics] (rev 02)
DeviceName:  GPU
Subsystem: Intel Corporation CometLake-U GT2 [UHD Graphics]
Kernel driver in use: i915
https://linuxconfig.org/graphics-driver-check-on-ubuntu-22-04
glxinfo -B
name of display: localhost:10.0
display: localhost:10  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Mesa/X.org (0xffffffff)
    Device: llvmpipe (LLVM 13.0.1, 256 bits) (0xffffffff)
    Version: 22.0.5
    Accelerated: no
    Video memory: 3634MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 4.5
    Max compat profile version: 4.5
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 13.0.1, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 22.0.5
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.5 (Compatibility Profile) Mesa 22.0.5
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
vainfo
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.14 (libva 2.12.0)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 ()
Steven_Intel
Hello mobuche,
I am sorry you are having issues with your Intel graphics. I'll be glad to assist you.
In order to better assist you, please provide the following information:
  • Are you using an Intel NUC? If so, what is the model of your NUC?
  • Have you installed the latest graphics available for your system?
Steven G.
mobuche
Hi Steven,
Yes it is an Intel NUC, product id=bxnuc10i5fnhm, I guess this one: https://ark.intel.com/content/www/us/en/ark/products/214591/intel-nuc-10-performance-kit-nuc10i5fnhn.html
I didn't install the latest drivers because it doesn't seem to be to so easy to do, and the drivers are not so old (22.3.1). Do you know if there are some fixes around this topic since this version ? Of course, if the answer is yes I will try to update the drivers.
Best
Steven_Intel
Many thanks for your reply.
The Intel® NUC10i5FNHN does not officially support Ubuntu or any other Linux operating system, therefore, there are no official drivers we can provide.
Our best recommendation is to check on Linux forums for further information/assistance.
Supported Operating Systems for Intel® NUC Products: https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html
Steven G.
