22678 Discussions
How to enable panel_fitter via command line in Linux on a i3-6100 CPU?
JJimC
When using the "intel_panel_fitter -l" command I can see that I have the anticipated 3 pipes (A,B,C) and that pipe A is active. However that pipe indicates panel_fitter is disabled; e.g. "- pf disabled". How do I enable the panel fitter for that pipe?
Hi Swegian,
I was investigating about this command, but I could not find a way to enable the panel fitter on Linux. What I suggest you is to get in the Intel Open Source Community, there you will get in contact with other Open source users that may help you.
Check here the 01 Intel Open Source Community
https://01.org/community https://01.org/community
Hellen.
Hi Swegian,
Hellen.
