23077 Discussions
How to set colorspace (RGB or YCrBr) and level output (0-255 or 16-235) with X4500HD integrated video card
Hello, i need your help!
i Have P5Q-EM / G45 chipset motherboard for my desktop that i use how HTPC. (using HDMI output)
I don't found any setting in the driver of integrated video card (Intel X4500HD)
For me is indispensable can modify these settings
Can you help me? Anyone know how this card go out at deafult throught the HDMI output? (rgb...YCrBr...0-255....16-236...etc etc)
Thank you
DKnow2
Valued Contributor I
The input color format for digital displays should be determined at the monitor as far as I can see. If automatic detection is not desired I don't see how to change that even with an nVidia card, although the card can be selected instead of application control. Any color profile is also automatically loaded upon installation. The display menu should be adequate but I'm not sure about the level output.
DKnow2
I did find a level output setting (color settings > advanced > dynamic range) with a nVidia GT240 control panel but haven't found any for integrated video. On my system this is disabled (grayed) with a DVI connection.
pls i need your help!!!
is very important for me have the possibility to chose the level output (normal 16-235 or expanded 0-255)
