22722 Discussions
How to use Iris (R) Xe Graphics from my Laptop with 3 Monitors
100janovic
Hello everyone
Can someone tell me why I have occasional image interruptions on monitors, I adjusted
two monitors to work at 30 MHz, and the third one works at 59 MHz (I can't reduce it to MHz).
Is it even possible to use this graph with 3 Monitors?
Attached is still mine, Graphics Analyze with all the information.
David_G_Intel
Hello 100janovic
Thank you for posting on the Intel️® communities. To investigate, please share with us the following:
  • What is the model of the system?
  • Does this happen with Windows 10? (Non-LTSC)
  • When did this issue start?
  • Do you use any adapters, converters, or docking stations?
  • What are the exact resolutions used?
  • Intel® System Support Utility (Intel® SSU) results
David G
100janovic
Hi David
Thanks for your feedback.
I use windows 10.
Docking Station ThinkPad.
Please find attached the text analysis I did with your Software that you sent me.
Thank you for your suggestion.
For me, the problem is only one monitor, sometimes there are image interruptions.
Best Regards
Neven
David_G_Intel
Thank you for the update. In this case, the processor does support up to 4 monitors with the resolutions posted on our website:
This could be limited by the laptop specs and if you're using a dock, that could also modify the video signal. Checking the laptop specs it seems to only have two graphics output ports, please check with the manufacturer the compatibility with the dock and confirm how many monitors are supported. You can also update the graphics driver using the version provided on Lenovo's website, you might need to use a standard (Non-LTSC) version of Windows 10 for the update. Let us know if you have any questions.
David G
TonyJ1
Hi David,
Would you please provide information on how to verify or the proper procedure for adding a 4th monitor?
Running:
Windows 10 on a Dell with a CODi dock
Processor: 13th Gen Intel(R) Core(TM) i7-1355U, 1700 Mhz, 10 Core(s), 12 Logical Processor(s)
Display card: Intel(R) Iris(R) Xe Graphics
Thank you in advance.
MUC
Honored Contributor I
The only Dell laptop I can find in the catalog featuring an i7-1355U is the Inspiron 15 3530. This laptop has an HDMI 1.4 port as its only video output. However, the CODi docking stations connect via USB-C, which means that the source device must be able to output video signals via USB-C using DisplayPort mechanisms, so DP++ or ideally Multi Stream Transport (MST). This is not the case with the Inspiron 15 3530. The USB-C port only provides a 5 Gbps data connection, no video.
David_G_Intel
David G.
David_G_Intel
David G.
