23262 Discussions
I am not sure if I am in the right Forum
Andrew44
That my device manager show me. It is all about vendor 8086 (Intel), the devices are 1041/1046/1048, 51A3/51A4/51A8/51AB and 463E/464F/461B.
The short answer is easy: There are devices without driver. The problem is that I can not find the driver.
But I would like to know where the devices are: Are the devices physical part of my computer? Or are the devices maybe old registry items?
Hardware: MSI Cubi5 12M-070TH
Windows 10 Pro
AlHill
Install the chipset.inf available from MSI for your motherboard.
Then, run windows update.   Many of those should  be found automatically by windows update.
Then, for the remaining missing drivers, go to the download page on the msi site (the same page where you found the chipset inf), and locate the various missing drivers.
In short, MSI has the drivers you need for their board.
https://www.msi.com/Business-Productivity-PC/Cubi-5-12M/support#driver
Note that MSI does not support W10 on your device.  Only W11.
Andrew44
Thank you.
I do not like the fact, but I will upgrade to Windows 11 now.
Andreas
AlHill
Immediately after you upgrade to w11, make sure you run the chipset.inf.
Andrew44
The upgrade to Windows 11 do not work.
So I will live with the missing drivers.
Thanks for your help.
Andreas
