22649 Discusiones
I am working with Adobe Premiere Pro 2019 and it asks me to instal a more recente version of the driver (100.2686 or above). From the latest versions which one should I instal?
MSerr5
Principiante
2.003 Vistas
0 kudos
1 Solución
AlHill
Superusuario
1.712 Vistas
Well, since you are on 1803, you should upgrade to 1903, as 1803 only has a few months of support remaining.
Since you posted in the graphics forum, I assume you are having an issue with graphics.
After you upgrade to 1903, use the latest graphics driver from Lenovo. If that does not solve your problem, then you "could" try using the latest DCH driver from here:
https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?v=t
However, you should try the latest Lenovo driver for your graphics first.
Doc
Ver la solución en mensaje original publicado
6 Respuestas
AlHill
Superusuario
1.712 Vistas
What is your processor model number?
What operating system? Windows 10? what version? 1903?
Doc
MSerr5
Principiante
1.712 Vistas
LENOVO 80SM
  • System Manufacturer LENOVO
  • System Model 80SM
  • System Type Mobile
  • Motherboard Manufacturer LENOVO
  • Motherboard Product Toronto 5A2
  • BIOS Version 0XCN23WW
  • SMBIOS Version 2.8
  • Secure Boot On
Microsoft Windows 10 Home (64 bits)
  • Version 1803
  • OS Build 10.0.17134
  • Build Branch rs4_release
  • Locale Portuguese (Portugal)
  • Windows Directory C:\Windows
  • System Directory C:\Windows\system32
  • .NET Framework Versions 2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 4.0.0.0, 4.7.03056
Processor
Intel® Core™ i5-6200U CPU @ 2.30GHz
  • Manufacturer GenuineIntel
  • Description Intel64 Family 6 Model 78 Stepping 3
  • Architecture x64
  • # of Cores 2
  • # of Threads 4
  • Processor Base Frequency 2300 MHz
  • Current Voltage 8.
  • Level 2 Cache 512 Kb
  • Level 3 Cache 3072 Kb
  • Processor Id 0x406E3
  • Revision 19971
I hope this helps. Thank you.
AlHill
Superusuario
1.713 Vistas
Doc
MSerr5
Principiante
1.712 Vistas
I did what you suggested, installed new windows update, and all new drivers update. It's all done and super. Problem solved! Thank you again for your support.
MSerr5
Principiante
1.712 Vistas
Ok, thank you, I'll do that.
AlHill
Superusuario
1.712 Vistas
Glad you have it working.
Doc
Responder
