will you share your intel gpu 630 hardware ID , then I will tell whether its supported or not
The hardware ID is PCI\VEN_8086&DEV_3E9B&SUBSYS_16531458&REV_00
try to type below commands and press enter
sfc /scannow
Dism.exe /online /Cleanup-Image /StartComponentCleanup
Dism.exe /Online /Cleanup-Image /RestoreHealth
restart the windows .
Use CCleaner to clean registry files an d junk files
try to update latest windows update build no 17134.472 ,
then try to type below commands and press enter
sfc /scannow
your hardware device ID is fully supported , i checked in the driver file
Now download the latest DCH_WHQL driver 25.20.100.6471 and install with admin rights
https://downloadmirror.intel.com/28435/a08/dch_win64_25.20.100.6471.exe
or this driver 25.20.100.6444
https://downloadmirror.intel.com/28148/a08/dch_win64_25.20.100.6444.exe
once completed installation , restart the windows
I've tried the above and got the error again:
" The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer"
I have the same problem, what if I can't update to the build. Will it still work.
Try to install this driver version
https://downloadcenter.intel.com/download/28289/Intel-Graphics-Driver-for-Windows-10
