23660 ディスカッション
I have problem with HD Graphics 530 driver
SGera2
ビギナー
11,485件の閲覧回数
Processor: i3-6100
System: Windows 7
HD Graphics 530 driver version: 21.20.16.4678
I want to play "Factory", but he require OpenGL 1.2 minimum.
Where can I found normal (human) driver with OpenGL support?
Also DirectX suxx too. If I try to run game with forced DirectX mode, it says "Goodby":
0.056 System info: [CPU: Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz, 4 cores, RAM: 8088MB]
0.056 Display options: [FullScreen: 1] [VSync: 0] [UIScale: 100%] [MultiSampling: OFF] [Screen: 255] [Lang: ru]
0.056 Available display adapters: 1
0.056 [0]: \\.\DISPLAY1 - Intel(R) HD Graphics 530 {0x8000005, [0,0], 1920x1080, 32bit, 60Hz}
0.056 Create display on adapter 0. Size 1280x720 at position [310, 162].
0.058 D3D9: Skipping adapter 0 as it doesn't have any available modes.
0.058 D3D9: al_get_d3d_adapter_from_win_adapter failed. Using adapter -1 instead
0.061 d3d_create_display failed.
0.061 Failed to create display (NULL)
0.061 Error Util.cpp:62: Failed to initialize display device!
1.393 Goodbye
0 件の賞賛
17 返答(返信)
Stefan3D
名誉コントリビューター II
9,962件の閲覧回数
Looks like the driver hasn't been installed properly for some reason.
The pull-down menu reads "GDI generic" (Microsoft basic display adapter)
Download latest Windows 7 driver from here: https://downloadcenter.intel.com/download/26836/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88345 Download Intel® Graphics Driver for Windows* [15.45]
Install once again.
After successful installation it should read OpenGL 4.4
SGera2
ビギナー
9,962件の閲覧回数
I can do this for the fourth time:
Old driver deleted
Install new driver
Nothing changed
Stefan3D
名誉コントリビューター II
9,962件の閲覧回数
Open device manager, check for yellow bangs.
In device manager open graphics card / properties / events.
Scroll down to last event, it should read sth. like "device installed ... status 0x0".
If not, open all events and check at which step installation failed.
SGera2
ビギナー
9,962件の閲覧回数
Events? Who is events?
Stefan3D
名誉コントリビューター II
9,962件の閲覧回数
Sorry for confusion,
i'm just working on a Windows 10 system, which has an additional tab for events.
I have no Windows 7 rig handy, please help yourself via https://www.google.de/search?q=windows+7+events https://www.google.com/search?q=windows+7+events
Otherwise create a report with https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility for Windows, so that an Intel agent can take a look at it.
SGera2
ビギナー
9,962件の閲覧回数
I reinstalled my driver between 12:51 and 12:53 (Ukraine time). There is no error or notice in this time interval:
Also, I made a report with this utility. Here: http://xcont.com/report.txt http://xcont.com/report.txt
Stefan3D
名誉コントリビューター II
9,962件の閲覧回数
The SSU report shows an issue, it should not read 1.7.34, but the same version as below
- "Display"
Intel ® Graphics Driver Version:"1.7.34.0"
Driver Version:"21.20.16.4678"
Other things you can try:
Instead of using setup.exe
https://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html Manually Install an Intel® Graphics Driver in Windows 7*
Restore your system to a restore point before the issue appeared first time
https://support.microsoft.com/en-us/help/17127/windows-back-up-restore https://support.microsoft.com/en-us/help/17127/windows-back-up-restore
SGera2
ビギナー
9,962件の閲覧回数
Yes, I used both variants - win64_154519.4678.exe and win64_154519.4678.zip.(and one time tried to use win64_154605.4771.zip (dosn't work))
I can't restore my system, because this option disabled in my system.
従業員
9,962件の閲覧回数
Hello xcont,
I understand you are trying to install latest graphics driver in your computer so you can play "Factory".
Let me apologize for any inconvenience this issue may be causing to you.
According to Intel® System Support Utility report you sent to us latest graphics driver is currently installed in your computer.
Now that latest graphics driver has been installed open the computer game and check if you get or not an error message. If you get an error message on the screen, let me know what it is so we can help you further.
Fred D.
SGera2
ビギナー
9,962件の閲覧回数
Factory said:
Also, Factory create log-file, and log-file said:
0.015 System info: [CPU: Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz, 4 cores, RAM: 8088MB]
0.016 Display options: [FullScreen: 1] [VSync: 0] [UIScale: 100%] [MultiSampling: OFF] [Screen: 255] [Lang: ru]
0.016 Available display adapters: 1
0.016 [0]: \\.\DISPLAY1 - Intel(R) HD Graphics 530 {0x8000005, [0,0], 1920x1080, 32bit, 60Hz}
0.016 Create display on adapter 0. Size 1280x720 at position [310, 162].
0.039 WGL_ARB/EXT_pf not supported.
0.044 Allegro requires at least OpenGL version 1.2 to work.
0.046 Failed to create display (NULL)
0.046 Error Util.cpp:62: Failed to initialize display device!
4.106 Goodbye
従業員
9,962件の閲覧回数
Hello xcont,
I am sorry to hear issue persists even with latest graphics driver.
Have you tried reinstalling the computer game?
Does the issue happen with that specific game/application?
Fred D.
SGera2
ビギナー
9,962件の閲覧回数
Thats sounds like "go on Factory forum".
I have tried reinstalling Factory game. Also, I have tried to reboot my computer. And also I have checked my monitor - it's turned on!
従業員
9,962件の閲覧回数
Hello xcont,
I have searched online, but I am not able to find a game for Windows® 7 called "Factory".
To better assist you with your request, please provide us with the link to the website of this game.
Xavier A.
SGera2
ビギナー
9,962件の閲覧回数
従業員
9,962件の閲覧回数
Hello xcont,
Thanks for the additional information you sent to me.
I will do further research about this and then come back to you.
Fred D.
従業員
9,962件の閲覧回数
Hello xcont,
I was trying to replicate the issue in our lab, but the game is working fine on my end.
There is newer version of the graphics driver available, and I would like you to give it a try. You can download it from this link https://downloadmirror.intel.com/27227/a08/win64_154521.4821.zip https://downloadmirror.intel.com/27227/a08/win64_154521.4821.zip
Please install the driver with the steps that are on this other link https://www.intel.com/content/www/us/en/support/articles/000005474/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005474/graphics-drivers.html
Let me know if issue persists or not.
Fred D.
従業員
9,962件の閲覧回数
Hello xcont,
I was wondering if you were able or not to try the graphics driver I provided. In case issue persists just let me know.
Fred D.
返信
