Decided to use an old 1366x768 resolution monitor as a second screen for my I3-1115G4 laptop, however, windows recommends using 1024x768 and "list all modes" option doesn't show 1366x768.
Used both generic pnp monitor driver and the driver offered by the manufacturer, but neither of them showed any change.
Is it the graphics adapter or should i seek for the solution somewhere else?
Thanks in advance.
Hello jorgera,
Thank you for posting in the Intel Community.
In order to identify the root cause of the issue you're experiencing, kindly provide the following information:
1. The make and model of your monitor:
2. The make and model of your laptop:
3. What type of video cable and port are you using?
4. Intel® System Support Utility Logs of your computer. This will help us check your system configuration in-depth and attach it to this thread. Here's the link on how to generate the logs: https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html
Norman S.
Hello jorgera,
Norman S.
Hello jorgera,
Norman S.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
