22751 Discussions
IGCC Combine monitors not working if a monitor orientation is Flipped
Adrian_Vasile_C_
Hello
I am trying to combine my two monitors (in portrait mode) into one.
With my hardware I have to use flipped orientation for the left monitor, because the viewing angle matters for this monitor.
When I combine monitors in the Graphics Command Center,, the command appears to work but the resulting orientation of my monitor is wrong. The image is no longer flipped.
That is, the Combine Monitors command ignores the flipped orientation and there is no way and no alternative to explicitly specify this orientation when using Combine Monitors command from the menu.
Can this be fixed please ? Is there a way to combine monitors with flipped orientation ?
emc333
Having same issue, after combining monitors, intel command center is changing flipped monitor setting. Hope it will be solved
