電腦同時使用AMD顯卡跟INTEL內顯intel hd graphics 4400,如果BIOS是設為PEG→IGD,雙顯示輸出,但只使用一台螢幕的狀況下,插顯卡的螢幕換內顯W10能自動偵測螢幕,螢幕換回插顯卡卻無法自動偵測螢幕,若BIOS設為IGD→PEG,螢幕插內顯換插顯卡在插回內顯,就沒有該狀況,發現原因W10 1809疑似跟微軟自帶的跟INTEL官網提供的顯示晶片驅動不匹配,只要不是安裝主機板原廠光碟提供的INTEL顯示晶片版本15.36.64.3650就是有該狀況發生,如果就是硬要使用INTEL官網的驅動跟PEG→IGD問題則無解
官網還有其他合適版本的INTEL HD 4400顯示晶片驅動可以更新(我全部試過都一樣)
爛INTEL死不提供,寧願要使用者,要嘛使用微軟的要嘛使用主機板商提供的WIN8版本,不能證實可能是BUG嗎
然到歸咎於需求度不高(全世界只有我有該狀況)INTEL不願意修正BUG
LLIN48, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
The manufacturer of the computer has the option to do customizations on their products, they can enable and disable options in the BIOS as well as some features and functions.
The Intel® graphics drivers are generic, meaning they might or might not work with your system, we recommend to install the graphics driver provided by the manufacturer of the computer since that driver was customized by them work with your specific platform.
You mentioned there is a graphics driver available in your CD, that CD was provided by the OEM (Original Equipment Manufacturer), so in this case, the best thing to do will be to get in contact directly with them so they can verify and confirm if the configuration for hybrid graphics that you are trying to use is possible, if a BIOS update is needed or if there is a BIOS setting that needs to be enable or disable.
Alberto R.
可是主機板原廠光碟的驅動最高只支援Windows 8,雖然Windows 10也可以安裝,但我不保證穩定性,INTEL官方能評估修正此問題的版本的Windows 10顯示晶片驅動,並放在下載區供下載?官網目前最新驅動為(2019/3/19)版本15.40.42.5063
LLIN48, Thank you for your response.
The proper graphics driver for your computer is provided by the manufacturer of it, even though the device works with Intel® HD Graphics 4400, the OEM has the option to limit, modify or change basically customized the settings in your unit.
If the OEM validated the system to work with Windows* 10 then they should have all the drivers available for it, including the graphics drivers, otherwise to keep using Windows* 8 will be the option for this scenario, since installing Windows*10 might create instability to your platform.
There is no official information coming from Intel® in reference to new driver releases for ntel® HD Graphics 4400.
Alberto R.
爛INTEL死不提供寧願要使用者,要嘛使用者使用微軟的要嘛使用主機板商提供的WIN8版本,不能證實可能是BUG嗎
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
Topic Options
