20948 Discussions
INTEL RELEASED 7TH MODERN GRAPHICS DRIVER V DCH_IGCC_26.20.100.6709 FOR WINDOWS 10 64 BIT 18-04-2019
RAJU2529
New Contributor III
On 18-04-2019 Intel inc released seventh modern graphics drivers (UMD_IGCC) v26.20.100.6709 only for windows 10 64bit
Supported OS versions::
Microsoft Windows® 10-64 - Fall Creators Update (1709)
Microsoft Windows® 10-64 - April 2018 Update (1803)
Microsoft Windows® 10-64 - October 2018 Update (1809)
Microsoft Windows® 10-64 – May 2019 Update (1903)
I am sharing the direct downloading links from intel website.
for end user consumer
https://downloadmirror.intel.com/28731/a08/dch_igcc_win64_26.20.100.6709.exe
for IT professional
https://downloadmirror.intel.com/28731/a08/dch_igcc_win64_26.20.100.6709.zip
for release notes .pdf
https://downloadmirror.intel.com/28731/eng/ReleaseNotes_DCH_iGCC_26.20.100.6709.pdf
Warning::
These new drivers labeled as Windows DCH graphics drivers aren't backward compatible with our previous graphics drivers we are now labeling Legacy. This means if later you want to revert to a Legacy driver you will need to uninstall the driver via Windows Apps and Features and reboot the system before installing a Legacy driver. Failure to do so may result in minor to major system instability.
DO NOT use the INF / Have-Disk method to install or uninstall this driver as it bypasses the Intel installer designed to install these new drivers, thereby possibly resulting in minor to major system instability. For this reason, we're not providing the ZIP file for the next several driver releases while users transition to this new Microsoft driver platform.
CONTENTS OF THE PACKAGE::
• Intel® Graphics Driver
• Intel® Display Audio Driver (10.26.00.06)
• Intel® Media SDK Runtime
• Intel® OpenCL* Driver
• Intel® Graphics Settings
• Vulkan* Runtime Installer (1.1.97.0 )
Supported extra features::(from processor)
• Supports Open GL 4.5
• Supports Open CL 2.1 or 2.0 or 1.2
• Supports Vulkan 1.1.101
Highlights of this driver 26.20.100.6709::
• Windows® 10 May 2019 Update launch driver
• It introduces support for the new DirectX* 12 Shader Model 6.4 compiler on 7th Generation Intel® Core processors or higher (Intel® HD Graphics 610 or higher).
• This driver is provided with the early access release of the brand-new Intel® Graphics Command Center.
• The Intel® Graphics Command Center (IGCC) is a software interface that provides consumers a modern design to optimize their visual experience – built on community feedback, and designed for simplicity and ease of use:
• This launch driver is WDDM 2.6 compliant and ready for the Windows 10 May 2019 update.
• IGCC scans for installed games to provide 1-click optimization of in-game settings based on the user’s hardware, and the ability to create custom game profiles to directly tune individual game settings.
• Additionally, IGCC helps consumers understand graphics settings with simple explanations and before-and-after images to recognize how each setting will tax their hardware.
GAMING HIGHLIGHTS::
Join the Industrial Revolution of the 19th century and start building your industry empire with Anno 1800*, help save humanity from a zombie invasion in World War Z* or use your hearing sense to investigate crimes in Unheard* on Intel® UHD Graphics 620 or better.
DEVELOPER HIGHLIGHTS::
• This driver is WDDM 2.6 compliant.
• Support for DirectX* 12 Shader Model 6.4 compiler.
• Support for PSO cache for Compute Shaders.
• Various performance improvements for D3D12 MetaCommands in DirectML.
PERFORMANCE IMPROVEMENTS::
• Power savings improvements for integrated panels.
KEY ISSUES FIXED::
• This driver contains stability and security improvements.
• Intermittent crashes or hangs may occur in Devil May Cry 5* (DX11).
• Minor graphics anomalies may be observed in Re-Legion*, Arma 3* (6th generation processors only) and Dreamfall the Longest Journey.
• Rise of the Tomb Raider might display an error message when running DX12.
KNOWN ISSUES::
• Minor graphics anomalies may be observed in Apex Legends* (low quality settings with TSAA disabled on 6th generation Processors only), Devil May Cry 5* (DX12), Generation Zero*, and Tom Clancy's The Division 2* (DX12).
• Intermittent crashes or hangs may be seen in Anno 1800* (DX12) and World War Z* (Vulkan).
• Corruptions may be seen in video recorded by Cyberlink* screen recorder.
RAJU2529
New Contributor III
The following Intel core processors hardware device IDs are supported by this driver 26.20.100.6709
; SKYLAKE
%iSKLULTGT1%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_1906
%iSKLULTGT2%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_1916
%iSKLULXGT2%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_191E
%iSKLDTGT2%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_1912
%iSKLULTGT2f%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_1921
%iSKLULTGT3e%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_1926
%iSKLULTGT3%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_1923
%iSKLULTGT328W%    = iSKLD_w10_DS, PCI\VEN_8086&DEV_1927
%iSKLDTGT1%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_1902
%iSKLHaloGT1%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_190B
%iSKLHaloGT4%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_193B
%iSKLHaloGT3fe%    = iSKLD_w10_DS, PCI\VEN_8086&DEV_192B
%iSKLHaloGT2%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_191B
%iSKLSRVGT3e%      = iSKLD_w10_DS, PCI\VEN_8086&DEV_192D
%iSKLSRVGT4%       = iSKLD_w10_DS, PCI\VEN_8086&DEV_193A
%iSKLWSGT2%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_191D
%iSKLWSGT4%        = iSKLD_w10_DS, PCI\VEN_8086&DEV_193D
; APOLLO LAKE
%iBXTGTP%          = iBXTD_w10_DS, PCI\VEN_8086&DEV_5A84
%iBXTGTP12%        = iBXTD_w10_DS, PCI\VEN_8086&DEV_5A85
; KABY LAKE
%iKBLULTGT1%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_5906
%iKBLULTGT2%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_5916
%iKBLULTGT2F%      = iKBLD_w10_DS, PCI\VEN_8086&DEV_5921
%iKBLULTGT3E15%    = iKBLD_w10_DS, PCI\VEN_8086&DEV_5926
%iKBLULTGT3E28%    = iKBLD_w10_DS, PCI\VEN_8086&DEV_5927
%iKBLULXGT2%       = iKBLD_w10_DS, PCI\VEN_8086&DEV_591E
%iKBLDTGT1%        = iKBLD_w10_DS, PCI\VEN_8086&DEV_5902
%iKBLDTGT2%        = iKBLD_w10_DS, PCI\VEN_8086&DEV_5912
%iKBLHALOGT1%      = iKBLD_w10_DS, PCI\VEN_8086&DEV_590B
%iKBLHALOGT2%      = iKBLD_w10_DS, PCI\VEN_8086&DEV_591B
%iKBLWGT2%         = iKBLD_w10_DS, PCI\VEN_8086&DEV_591D
%iKBLULTGT2R%      = iKBLD_w10_DS, PCI\VEN_8086&DEV_5917
; AMBER LAKE
%iAMLULXGT2R%      = iAMLD_w10_DS, PCI\VEN_8086&DEV_591C
%iAMLULXGT2R7W%    = iAMLD_w10_DS, PCI\VEN_8086&DEV_87C0
; COFFEE LAKE
%iCFLDTGT1%        = iCFL_w10_DS, PCI\VEN_8086&DEV_3E90
%iCFLDTGT2%        = iCFL_w10_DS, PCI\VEN_8086&DEV_3E92
%iCFLDTWSGT2%      = iCFL_w10_DS, PCI\VEN_8086&DEV_3E96
%iCFLHALOGT2%      = iCFL_w10_DS, PCI\VEN_8086&DEV_3E9B
%iCFLHALOWSGT2%    = iCFL_w10_DS, PCI\VEN_8086&DEV_3E94
%iCFLULTGT3W28%    = iCFL_w10_DS, PCI\VEN_8086&DEV_3EA5
%iCFLULTGT3W28EU42% = iCFL_w10_DS, PCI\VEN_8086&DEV_3EA8
%iCFLDTGT1W35%     = iCFL_w10_DS, PCI\VEN_8086&DEV_3E93
%iCFLDTGT2W35%     = iCFL_w10_DS, PCI\VEN_8086&DEV_3E91
%iCFLDTGT2S8S2F1F% = iCFL_w10_DS, PCI\VEN_8086&DEV_3E98
%iCFLHALOGT1H2F1F%   = iCFL_w10_DS, PCI\VEN_8086&DEV_3E9C
; WHISKEY LAKE
%iWHLULTGT2U42U2F2%  = iWHL_w10_DS, PCI\VEN_8086&DEV_3EA0
%iWHLULTGT1U41FU2F1F% = iWHL_w10_DS, PCI\VEN_8086&DEV_3EA1
; GEMINI LAKE
%iGLKGT2E18%       = iGLKD_w10_DS, PCI\VEN_8086&DEV_3184
%iGLKGT2E12%       = iGLKD_w10_DS, PCI\VEN_8086&DEV_3185
RAJU2529
New Contributor III
The following INTEL graphics cards or controllers are supported::
9th Generation Intel® Core™ processors with Intel® UHD Graphics 630
8th Generation Intel® Core™ processors with Intel® Iris® Plus Graphics 655
8th Generation Intel® Core™ processors with Intel® UHD Graphics 610/620/630/P630
7th Generation Intel® Core™ processors with Intel® Iris® Plus Graphics 640/650
7th Generation Intel® Core™ processors with Intel® HD Graphics 610/615/620/630
Intel® Xeon® processor E3-1500M v5 family with Intel® HD Graphics P630
Pentium Processors with Intel® HD Graphics 610
6th Generation Intel® Core™ processors with Intel® Iris® Pro Graphics 580
6th Generation Intel® Core™ processors with Intel® Iris® Graphics 540/550
6th Generation Intel® Core™ processors with Intel® HD Graphics 520/530
Intel® Xeon® processor E3-1500M v5 family with Intel® HD Graphics P530
Intel® Xeon® processor E3-1500M v5 family with Intel® Iris Pro Graphics P580
Intel® Core™ M processors with Intel® HD Graphics 515
Pentium® and Celeron® Processors with Intel® HD Graphics 500/505/510
Pentium® and Celeron® Processors with Intel® UHD Graphics 600/605
sources are taken from https://downloadcenter.intel.com/download/28731/Intel-Graphics-Windows-10-DCH-Drivers?product=96551
Just I am sharing the information to the intel users
RAJU2529
New Contributor III
Pic01.JPGThanks to the graphics driver development team for giving new UI Graphics command center and its graphics driver . But still I have not tested any games on this driver .Pic07.JPGPic06.JPGPic05.JPGPic04.JPGPic03.JPG
