23102 Discussions
Installed Windows 7 which is 64 Bit OS with Intel r HD Graphic Card ! Problem is Screen Resolution is Set to 1920 x 1080 which is showing Display Half in Size ! How to set Resolution Size to 1920 x 1200 which i do not see in the Setting ! Will that help i
SBEJU
Hello There !
I have Installed Windows 7 ......64 Bit OS with Intel r HD Graphic Card ! Problem is Screen Resolution is Set to 1920 x 1080 which is showing Display Half in Size ! How to set Resolution Size to 1920 x 1200 which i m not able to see that in Screen Adjustment Setting ! And i think that will help in setting Display to its Full Screen Size, i guess? Monitor is Dell 24 Inch ! Ex: While Browsing Facebook, i m able to see only Half Screen Size which giving unpleasant experience in browsing ! I tried to Uninstall Graphic Card Driver and Installed Freshly again ..but failed to see any change ! How to solve this ?
Allan_J_Intel1
I would the exact processor model for your computer.
Click the Windows icon, and then right-click Computer .
Select Properties .
Find System Type on the Properties window, and then note the processor model.
Allan.
Allan_J_Intel1
Select Properties .
Allan.
