23768 Discussions
Intel 11th-14th Generation Gen Processor Windows Driver
CRogerBlair
First, I apologize for not replying to your requests for more information; I tried, but your email server always blocked my emails from “[email protected]”. I don’t understand why (and I’d appreciate it if you could tell me why it happened), but there was nothing I could do about it, so I’m trying again using “[email protected].” Please use the Gmail address.
My problem is that the “Intel 11th—14th Generation Gen Processor Windows Driver won’t update. When I run the Driver and Support Assistant, the driver shows up in the listing. When I click the Install button, the progress bar reaches about 90%, then the installer disappears, and D&SA starts over again in some kind of loop. The only way to stop the loop is to close the browser tab. (I use Firefox.) When I restart D&SA, I find the following entry:
 (see attachment)
The same thing happens when I run Firefox in Troubleshooting (Safe) Mode.
I was advised to generate an SSU report (attached) and to extract the driver and install it manually (the driver is unsigned, so Windows won’t install it).
Could you advise me on what to try next? (I hope this address isn’t blocked.)
n_scott_pearson
have you tried downloading the driver package and running it manually? You can get it here: https://www.intel.com/content/www/us/en/download/864990/intel-11th-14th-gen-processor-graphics-windows.html. Download it and run it As-Administrator.
Hope this helps,
CRogerBlair
I tried, but I got the same error--1000.
Mike_Intel
Hello CRogerBlair,
  1. Are you trying to update the Graphics driver of your i5-1334U?
  2. Let me also check, you are having this issue using Intel DSA and even manually downloading the driver?
  3. What are the troubleshooting steps that you tried before contacting us?
Michael L.
CRogerBlair
!. I assume that's what I'm doing.
2: Yes, I get the same result both when I try to install the driver directly and when I use the D&SA.
3, I have tried running the installer itself, extracting the driver from the installer for Windows to update with (which Windows refuses to do because the driver is unsigned), and doing a clean boot and running the installer (which also didn't work).
Mike_Intel
Hello CRogerBlair,
Michael L.
Mike_Intel
Hello CRogerBlair,
Thank you for the quick update.
Please try the steps in the link below and tell me if you are still having the same issue specially running the driver as Administrator:
Intel® Arc™ Graphics Driver Installer Won't Start
Michael L.
Mike_Intel
Hello CRogerBlair,
Michael L.
CRogerBlair
I saw your email and took the pictures. Now, I'm wrestling  with PPhone Link and Link to Windows.
CRogerBlair
Here are the pictures.
CRogerBlair
Here are the pictures:
Mike_Intel
Hello CRogerBlair,
Let me clarify, based on the pictures that you sent. Are you trying to install the Graphics driver during Windows installation?
Michael L.
CRogerBlair
I have tried through Windows installation, through the D&SA, and through the Device Manager--all have failed.
Mike_Intel
Hello CRogerBlair,
Thank you for the quick update and clarification.
Let's try to update the driver using DDU, this is done via safe mode.
Please refer to the link below for the steps on how to perform DDU and the direct link of the latest driver.
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® 11th – 14th Gen Processor Graphics - Windows*
Michael L.
Mike_Intel
Hello CRogerBlair,
Michael L.
Mike_Intel
Hello CRogerBlair,
I am sending another follow up to check if you were able to install the driver. Let me also add that you can contact the manufacturer of the system for further assistance and they may have their own OEM drivers that you can try as well.
Michael L.
