22682 ディスカッション
Intel AMT remote desktop and Serial Over LAN cause XE driver related BSOD
LeiNade
初心者
2,345件の閲覧回数
My system is Lenovo Thinkedge SE30 with vPRO. AMT has been configured.
Starting a Remote desktop or Serial Over LAN session remotely will immediately cause the system to crash with code "SYSTEM_SERVICE_EXCEPTION" and the related module igdkmdn64.sys.
Uninstalling the Xe graphic driver can prevent any crashes from happening.
0 件の賞賛
7 返答(返信)
LeiNade
初心者
2,343件の閲覧回数
Tried Intel® Manageability Commander and MeshCommander, and both of them behaved the same.
LeiNade
初心者
2,339件の閲覧回数
Log from Tried Intel® Manageability Commander
LeiNade
初心者
2,337件の閲覧回数
And here is the minidump
LeiNade
初心者
2,293件の閲覧回数
5: kd> !analyze -v
* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff801972eb9f6, Address of the instruction which caused the BugCheck
Arg3: ffffa38aec174c40, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1889
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 8583
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 421
Key : Analysis.Init.Elapsed.mSec
Value: 25841
Key : Analysis.Memory.CommitPeak.Mb
Value: 93
Key : Bugcheck.Code.DumpHeader
Value: 0x3b
Key : Bugcheck.Code.Register
Value: 0x3b
Key : Dump.Attributes.AsUlong
Value: 8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
FILE_IN_CAB: 040423-8312-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff801972eb9f6
BUGCHECK_P3: ffffa38aec174c40
BUGCHECK_P4: 0
CONTEXT: ffffa38aec174c40 -- (.cxr 0xffffa38aec174c40)
rax=0000000000000000 rbx=ffffb585246c5490 rcx=ffffb585246c5490
rdx=0000000000000001 rsi=ffffb5852de3e000 rdi=ffffb585246c5490
rip=fffff801972eb9f6 rsp=ffffa38aec175640 rbp=ffffb585246ef010
r8=000000006c0cfb63 r9=0000000000000004 r10=fffff8016dd65240
r11=ffffa38aec175698 r12=ffffb585246c5490 r13=ffffb5851ccb7db0
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050286
igdkmdn64+0x19b9f6:
fffff801`972eb9f6 4c8b00 mov r8,qword ptr [rax] ds:002b:00000000`00000000=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: csrss.exe
STACK_TEXT:
ffffa38a`ec175640 ffffb585`245f01c0 : fffff801`6dce086b ffff9c19`ec766f96 00000000`00000000 ffffb585`246c2010 : igdkmdn64+0x19b9f6
ffffa38a`ec175648 fffff801`6dce086b : ffff9c19`ec766f96 00000000`00000000 ffffb585`246c2010 fffff801`97330993 : 0xffffb585`245f01c0
ffffa38a`ec175650 fffff801`972dcb25 : ffffb585`2de3e000 00000000`00000001 00000000`00000000 ffffb585`249280c8 : nt!KiWakeQueueWaiter+0x9b
ffffa38a`ec1756a0 ffffb585`2de3e000 : 00000000`00000001 00000000`00000000 ffffb585`249280c8 00000780`00000000 : igdkmdn64+0x18cb25
ffffa38a`ec1756a8 00000000`00000001 : 00000000`00000000 ffffb585`249280c8 00000780`00000000 ffffb585`16e02280 : 0xffffb585`2de3e000
ffffa38a`ec1756b0 00000000`00000000 : ffffb585`249280c8 00000780`00000000 ffffb585`16e02280 ffffb585`24927010 : 0x1
SYMBOL_NAME: igdkmdn64+19b9f6
MODULE_NAME: igdkmdn64
IMAGE_NAME: igdkmdn64.sys
STACK_COMMAND: .cxr 0xffffa38aec174c40 ; kb
BUCKET_ID_FUNC_OFFSET: 19b9f6
FAILURE_BUCKET_ID: AV_igdkmdn64!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {12102b79-db74-3949-6de5-0951c15a29fa}
Followup: MachineOwner
Andres_Intel
従業員
2,275件の閲覧回数
Hello LeiNade,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having Blue Screen of Death issues, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
LeiNade
初心者
2,249件の閲覧回数
I will continue on the AMT subforum, thanks a lot for your help.
Andres_Intel
従業員
2,225件の閲覧回数
Hello LeiNade,
Thank you for your response.
As you are being helped on another thread, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
返信
