23269 Discussions
Intel ARC A750 stutters in War Thunder
AjrAlves
New Contributor II
Hey, good morning!
So, my system specs are the following:
Windows 11 22H2
Intel driver Version 4148 Beta (the problem also occurs with 4146 and 4125)
REBAR ON
ARC A750 ASRock
Ryzen 5 5600 @ 4.9GHz
32GB DDR4 3200MHz
Gigabyte B550M DS3H on BIOS F17b
2x NVMe drives (Adata Falcon and SN550)
EVGA 700W PSU
LG 24GN600
Game client: Steam
Well, as you can see in this older topic from me , I was having some issues with Zen 2 + ARC.
I upgraded the CPU to a Zen 3 part, re-imaged the computer and re-installed the game and drivers and my performance improved A LOT.
BUT, I'm having the following problems in War Thunder:
FPS stutters when moving the screen rapdly (drops from around 150 to 70)
FPS stutters when switching camera (just like a half second stutter, very annoying)
FPS stutters randomly (seem to even out during the match, but won't go away)
V-sync and/or smooth sync won't cap my FPS to my monitor's refresh rate (144Hz)
In the video I recorded, I show my system, the stutters I'm having, but for some reason it didn't pick my mic's audio.
I think DXVK would improve things in this games, but, sadly, this game won't open with the DLLs at it's folder.
Here you can see my recording on YouTube , but if you wan't to see it without compression, here's the Google Drive link
AjrAlves
New Contributor II
Up
Hugo_Intel
Hello AjrAlves
Thank you for posting on the Intel Communities. I am sorry you are experiencing performance issues when playing War Thunder on your Intel® Arc™ A750 Graphics.
We will need to further look into this issue, and you have already provided most of the information we need, I would like to ask just for the following:
  • Create a log file with the Intel® System Support Utility and attach it.
  • In regards, to the game not synchronizing the FPS to the monitor's refresh rate, Have you tried both Borderless Window and Fullscreen modes in the in-game settings? Does the issue happen in both?
Hugo O.
Hugo_Intel
Hello AjrAlves
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello AjrAlves
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards,
Hugo O.
Intel Customer Support Technician.
Hugo_Intel
Hello AjrAlves
Before we close this thread we want to let you know that we are looking into this issue and working on it. In case you want to follow up on the status you can reference the Bug ID 18025525621.
Hugo O.
AjrAlves
New Contributor II
Hey Hugo!
Sorry, I was in a trip.
Good to know that you guys are working on it.
Is there any info you need from me?
AjrAlves
New Contributor II
Also, is there a way I can check the status on this?
Hugo_Intel
Hello AjrAlves
In order to check the status of this issue you can reference the Bug ID 18025525621 in future threads or cases that you open with us since there is no estimated time for a fix to be out.
We would like to get the information from our first previous post so we can have more information about the issue it will be the logs from the Intel® System Support Utility, and that you please let us know if you have tried both Borderless Window and Fullscreen modes in the in-game settings to try to fix the synchronization issue with your monitor refresh rate?
Hugo O.
sebastien82300
Hello ,
i've bought an Intel Arc A770 Limited Edition GPU , i play WarThunder (Tanks) but performance overall is really bad , even with lower resolution and effects , and gpu still over 70% usage , did you working on drivers and performance upgrade ?
sebastien82300
Hello , i ve got bad perf with my a770 , i found this :
go into game files , edit  config.blk   with notepad
change line driver:t="auto"     to   :      driver:t="dx10"
then , save , and change the file to read only  in properties
it run perfect for me , way  better than  dx12
if you want change setting in game uncheck read only  , etc
have fun 🙂
Hugo_Intel
Hello @sebastien82300
Thank you for posting on the Intel Communities. We appreciate that you shared this workaround with us. Also, please note that we are working on an official fix under Bug ID 18025525621 in case you want to check the status later on you can reference the Bug ID.
Hugo O.
Hugo_Intel
Hello AjrAlves
Please, if possible share whit us the information requested from my previous post in order to pass it on to the corresponding team.
Hugo O.
sebastien82300
Intel Arc GPU Graphics Drivers 101.4311 (beta) seems to perform better
sebastien82300
https://www.techpowerup.com/download/intel-arc-graphics-drivers/
not yet avalaible on intel site  😅
Hugo_Intel
Hello AjrAlves
Hugo O.
RuskiARCski
Hello Intel,
Has this been fixed? I am trying to make a decision to purchase ARC over nvidia currently.
I enjoy Warthunder and need a card that can handle it.
Thank you!
