I got a Intel NUC 12 Enthusiast with a Intel A770m grafic chip. I am using 2 monitors, one is connected to the Display Port, the other to HDMI.
Its very frustrating, everytime I start a rallytv stream the second monitor on HDMI turns off. The whole windows setup changes to a 1 monitor setup. The only way to get it working again is by unpluging the HDMI cable and repluging it. Nothing else works. I use new HDMI 2.1 and DisplayPort 1.4 cables.
My guess is it has something to do with HDCP maybe? I had the same 2 monitors with my Nvidia 1050ti graficscard on my previous PC and never had this problem.
Is there any solution to this? is that a common problem with the A770m? Because this is a NUC device I dont believe I am the only one with this problem.
Drivers Installed: 31.0.101.4826 (latest at time of writing)
NUC Bios: 0058 (latest at time of writing)
Monitor 1: DP 1440p 120hz (variable refreshrate disabled), DP 1.4 cable on DP 2.0 port
Monitor 2: HDMI 1440p 75hz (no variable refreshrate supported), HDMI 2.1 cable on HDMI 2.1 port
Thanks for the help.
Hello Zernichthor,
Thank you for posting on the Intel®️ communities. I understand is frustrating when a monitor stop displaying image, I will be more than glad to help you.
To clarify this situation, please answer the following questions:
- Does the issue happen with older graphics driver versions?
- To now your system environment, attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Hello Zernichthor,
Were you able to run the Intel® SSU?
Andres P.
Hello Zernichthor,
Thank you for your response.
Happy to hear that the issue is fixed by connecting both monitors with DisplayPort, in case you want to continue testing the issue with the HDMI port please create a new thread we will be more than glad to help you.
For now, as per your request, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
