23784 Discussions
Intel Arc Control bug
Avi404
The software is displayed in a cut form, I tried to reinstall, and even reset the computer, the problem was not solved, (sorry for the English)
Andres_Intel
Hello Avi404,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having issues with your Intel® Arc™ Control, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Avi404
Hi, thanks for your reply
The software version is 1.69.5033.3
And she didn't work before.
The system logs are attached
Andres_Intel
Hello Avi404,
Thank you for your response, it has been very helpful.
Please follow the steps below and let me know the results:
  • I see you have a Beta version of Intel® Arc™ Control uninstall it following the steps below:
  1. Press the Windows key.
    1. Click on settings.
    2. Select Apps and then select Apps & Features.
    3. Search for Intel® Arc™ Control software.
    4. Click on it and select the option to uninstall.
Andres P.
Avi404
I used the beta version because the stable version doesn't work, both versions are displayed in a cropped form without difference
Andres_Intel
Hello Avi404,
Thank you for your response, all the information provided has been really helpful.
I was doing a research and Intel is currently investigating this issue. We are working very hard to fix it. We recommend having the drivers and software version up to date.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello Avi404,
Andres P.
Andres_Intel
Hello Avi404,
Andres P.
Andres_Intel
Hello Avi404,
Before we close this thread, as mentioned before we are working on this issue, as soon we have more details we will let you know.
Andres P.
Andres_Intel
Hello Avi404,
Thank you for your time.
We have been working on the investigation, the graphics driver 31.0.101.4575 which includes Arc Control 1.70.5084.2 has been published. Please complete the update, following the guidance on How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11, and test the fix.
Andres P.
Intel Customer Support Technician
Avi404
hi
Hi Thank you very much for trying to help, I have installed the version you mentioned, but despite all this the problem does not seem to be solved.
I have attached files that will help you understand the problem if you decide to continue solving itI have attached files that will help you understand the problem if you decide to continue solving itI have attached files that will help you understand the source of the problem.
In any case, I really appreciate the attempt to help 🫶
Andres_Intel
Hello Avi404,
Thank you for keeping us informed.
I will continue with the investigation and provide you with the next steps as soon as possible.
Andres P.
Andres_Intel
Hello Avi404,
I have been working on the investigation, please follow the steps below and let me know the results:
Andres P.
Avi404
I performed a clean install, but the problem remained exactly as it was, so I attached the files you requested.
Andres_Intel
Hello Avi404,
Thank you for your answer, and the logs shared.
I will continue with the investigation, as soon I have further details I will let you know.
Andres P.
Andres_Intel
Hello Avi404,
Thank you for your waiting.
Andres P.
Andres_Intel
Hello Avi404,
Andres P.
Andres_Intel
Hello Avi404,
Andres P.
