23832 Discussions
Intel Arc driver issue on vulkan
Omidv34
Sorry if this is not the correct place to ask but I'm observing a weird issue on Intel Arc gpus that I"m pretty sure related to driver. The issue happens in form of a TDR (vulkan device lost) when sampling a specific image after writing to it in a previous pass. Now why the issue is weird. First of all there is no validation error/warning whatsoever (tried all the validation layers). Second, the same hlsl code and host setup (same barriers, execution order, etc.) work fine with our DX12 backend. Moreever this is an Intel Arc gpu only as we tested our game on different NVidia and AMD gpus and saw no similar issue. I also tried Intel GPA Tool but it only supports DX12 to capture frames so probably have to wait for a Vulkan release. But aside from that, is there anything we can try to better debug the TDR?
Stefan3D
Omidv34
Thanks. I forgot to mention frame caputre with RenderDoc and PIX (for dx backend) doesn't show any critical error or visual issue. I also  used the captures to check the values read/written in the aforementioned passes but saw no unusual value.
Jose_Intel
Hello @Omidv34
Thank you for posting on the Intel️® communities.
I am sorry to hear that you have problems with Intel® Arc™ Graphics, and I’ll be more than happy to help you.
Please answer the following:
·      Are you using our latest graphics driver 31.0.101.4575?
·      Have tried using older driver versions?
·      Do you work or represent a software company?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Jose B.
Jose_Intel
Hello Omidv34
We hope you are doing fine.
Jose B.
Jose_Intel
Hello Omidv34
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
