22662 Diskussionen
Intel® Arc™ & Iris® Xe Graphics - Windows* Installation failed with error code 999
deshipley
Einsteiger
1.383Aufrufe
It will not install after several times.
6 Antworten
JeanetteC_Intel
1.334Aufrufe
Hello deshipley,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Could you please specify the driver version and provide the link you attempted to install that resulted in error code: 999?
2) Are you experiencing graphics issues that prompted you to update or install the driver?
3) How did you install the driver? Did you do it manually or use a driver updater tool?
Additionally, I highly appreciate you sharing your system configuration so I we can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  1. Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save. *Attach the SSU log file as you reply.
JeanetteC.
deshipley
Einsteiger
1.183Aufrufe
Here is the scan results
deshipley
Einsteiger
1.177Aufrufe
driver from intel support not working
JeanetteC_Intel
1.283Aufrufe
Hello deshipley,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions.
JeanetteC.
VARADHARAJAN
Geschätzter Beitragender II
1.266Aufrufe
@deshipley   What is the error messages you are getting while installing?
JeanetteC_Intel
1.199Aufrufe
Hello deshipley,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
Antworten
