23808 Discussions
Intel Arc gpu
Programinjo
Hello!
Can be done , to modify the fan curve and save it in gpu bios on arc gpu?
Hugo_Intel
Hello Programinjo
Thank you for posting on the Intel Communities
The fan curve for the Intel® Arc™ GPUs cannot be modified or saved from your system BIOS, instead, you need to use our Intel Arc Control Software to modify and set your preferred fan curve. You can find all the settings for the fan curve under the performance tab within Arc Control.
Hugo O.
Programinjo
not the mohterborad
Hugo_Intel
Hello Programinjo
The only option to modify the fan curve on our Intel® Arc™ GPUs would be through our Arc Control software which is bundled with the GPU's drivers.
Hugo O.
Programinjo
ok , but not in linux Opensuse Tumbleweed,make  Arc Control  for linux
Hugo_Intel
Hello Programinjo
At the moment there are no immediate plans to release Arc Control on Linux Linux-based operating System, however, I will be glad to pass your feedback to the corresponding team so it can be taken into consideration.
Hugo O.
Hugo_Intel
Hello Programinjo
We want to let you know that your feedback related to integrating Arc Control or Fan Control for Linux has been documented and passed to the corresponding team. We appreciate your feedback and support.
Hugo O.
Hugo_Intel
Hello Programinjo
As mentioned in our previous post your feedback was passed to the corresponding team. Since there are no further questions we will proceed to close this thread. Thank you for your feedback and support.
Hugo O.
