22980 Discussions
Intel Atom Z2760 in Windows 10 OpenGL workaround
AAlth
Hi all,
after experimenting a LOT!, by resetting and rebuilding my Lenovo Tablet IdeaPad 10" uncountable times, I found a way to enable finally OpenGL in Windows 10. I run Windows 10 build 1709. Kind of tricky to install or to make a clean install... Use a mini-USB connector to set-up a USB-Hub. You need a external Keyboard and mice; further a USB-Drive with the Win10 32bit installation. Create the installation media with the tool from Microsoft and then boot with from the USB-Drive(EFI)
Windows10 will install completely.
Wait for any system-updates to complete! Takes a while...
Install the Platform-driver of your Z2760.
Restart after the driver-installation is complete. I believe on other brands you have to install according to the manufacturer the same ways.
I have installed also the Klite codec pack afterwards with MPC included.
You will have the standard Intel Graphics Media accelerator installed, but no OpenGL or WDDM 1.2 support!
Download the windows7 32bit AGM 3600 Driver from Intel. Unpack. Enforce the driver installation. Windows will complain it is not compatible. Ignore it.
Restart the System. The Graphic-Adapter is now with an exclamation mark, cannot start Intel AGM 3600. Only the basic windows driver is loaded.
Download from windows update now the latest driver. It will be the latest available: Intel(R) Graphics Media Accelerator; 11/15/2013; 9.14.3.1177;
Reboot the system. Now you have OpenGL support, WDDM 1.2, DirectX.
PLEASE be careful about. It worked for me! It does NOT mean it automatically works for your system also, but you can give it a shot. 🙂
I am not an Graphics-Expert, but I have found out the OpenGL Drivers are installed from the Windows7 and reside with the settings in the registry. Many people report the same issues with an upgrade to Windows 10 from 7 or 8 and drivers are working also for other devices, like Fingerprint, etc. Apparently the upgrade stores the HW Information. On a fresh Win10 installation this is lost. It seems the old driver writes this info into the registry and gives the support required.
I hope this helps a few people out there. So far I have no issues even with CAD Software or a few games I have tested.
Cheers 😄
Below my DirectX Diagnostic log:
System Information
Time of this report: 4/1/2018, 13:54:32
Machine name: DESKTOP-IINBQB6
Machine Id: {6D19CC5C-E2A2-4FE7-9617-698XXXXXX033}
Operating System: Windows 10 Home 32-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 20284
BIOS: 84CN22WW(V1.08)
Processor: Intel(R) Atom(TM) CPU Z2760 @ 1.80GHz (4 CPUs), ~1.8GHz
Memory: 2048MB RAM
Available OS Memory: 2008MB RAM
Page File: 1680MB used, 1479MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.16299.0015 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Graphics Media Accelerator
Manufacturer: Intel(R) Corporation
Chip type: Intel® Graphics Media Accelerator
DAC type: Internal LVDS, HDMI
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_08CF&SUBSYS_398417AA&REV_05
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 1003 MB
Dedicated Memory: 0 MB
Shared Memory: 1003 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.597180,0.354016), Green(0.335461,0.567883), Blue(0.151867,0.119641), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD0400
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: igdumd32.dll
Driver File Version: 9.14.0003.1177 (English)
Driver Version: 9.14.3.1177
DDI Version: 11.1
Feature Levels: 9_3,9_2,9_1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 11/15/2013 7:00:00 AM, 1994752 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-4B8F-11CF-8370-8719A4C2C435}
Vendor ID: 0x8086
Device ID: 0x08CF
SubSys ID: 0x398417AA
Revision ID: 0x0005
Driver Strong Name: oem34.inf:400ac85dd97eff91:generic32_VEN_8086&DEV_08CF:9.14.3.1177:pci\ven_8086&dev_08cf&subsys_398417aa
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeVC1_VLD
Deinterlace Caps: {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{44DEE63B-77E6-4DD2-B2E1-443B130F2E2F}: Format(In/Out)=(YUY2,X8R8G8B8) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_B...
Hello AndreasFfm
Thank you for joining the community and for the feedback provided I hope this information helps other peers; please bear in mind that the graphics controller for this processor supports only Windows® 8 and Windows® 8.1. please refer to the following link to confirm this information:
https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html
Leonardo C.
Hello AndreasFfm
Leonardo C.
